Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools 2020
  #71
Old 04-01-2020, 08:32 AM
bewk's Avatar
bewk bewk is offline
Default Re: 2020.3 is out
Eucon is just going back to the original .XML file for Pro Tools when you install a new version. Eucon defaults to naming the profiles based on the app itself so PT2020 gets its own appset when you launch Eucon and PT together. Your personal appsets for Eucon are saved to the user folder when you make changes to the file. You just need to locate your old file and either rename to accommodate PT 2020 or import as mentioned above.
For macOS: /Library/ApplicationSupport/Euphonix/UserSets/MC2User/MC_USER_SET__Root
For Windows: C:\Users\username\AppData\Roaming\Euphonix\UserSet s\MC2User\MC_USER_SET__Root
Your old file should be something like "Pro Tools 19Mac" or "Pro Tools 19PC".
-Chris
• MacPro (4,1 to 5,1) 12 Core 3.46 GHz // 96GB // AJA Kona LHi // OWC Mercury Elite Pro Quad, USB 3.0, eSATA
• PT HD|Native 2024.3 on macOS 12.7.4 (OpenCore Patcher 1.4.3 on Crucial SSD)
• Avid Dock, iPad 7th gen & EuCon 2023.11
• DADman/Eucon monitoring
• BSS (DAN + 100), QSC DCA 1644, JBL 7 Series
• MTRX Studio // 7.1.4
www.quesound.com
  #72
Old 04-01-2020, 10:28 AM
noiseboyuk noiseboyuk is offline
I have an issue / question here with routing folders.
I created a new project and added some regular folders, which auto-created busses Folder 1, Folder 2, Folder 3. Having done so, later on I figured I should have tried the new routing folders, so re-opened the project and added one. This created a bus Folder 1.1. I then dragged the tracks I had in Folder 1 in to my new Routing folder, expecting them to magically route to Folder 1.1
However all the tracks are still routed to the old Folder 1 bus. What happened? Did I:
A) misunderstand routing folders, and existing tracks don't get re-routed when you drag them in?
B) discover a bug? or
C) something else?
Guy Rowland
www.guyrowland.co.uk
www.sound-on-screen.com - Original audio clips of movies, TV shows and games, licensed as regular production music.
PT 2024 Ultimate; W11 Pro; Ryzen 9 7900; 64gb RAM; RME Babyface; UAD Quad Satellite USB; GTX 1050i
Macbook Air M2; 24gb RAM
  #73
Old 04-01-2020, 10:42 AM
XJENSEN XJENSEN is offline
Yes, that's what I understand from the documentation.
The folder track is not 'that' smart, so you still have to manage your routings if you drag tracks in (doesn't reassign automatically).
The other way around, you can still have tracks inside your folder being routed somewhere completely different outside that folder.
  #74
Old 04-01-2020, 11:00 AM
If you select some tracks and right click, then go to Move To->New Folder, and create a Routing Folder, there is a check box to route the tracks to the folder in that dialog.
Scott Gatteño
  #75
Old 04-01-2020, 11:10 AM
Is there a "move to existing folder" with that option? I was too hoping this could speed up template building not having to go through the manual track routing once the parent folder routing is set.
Thanks!
Frank.
  #76
Old 04-01-2020, 11:20 AM
Thanks!
Frank.
There is, but the tracks don't automatically route to the new folder that way. There should be a preference setting about whether or not to automatically route tracks when moving into an existing Routing Folder.
Scott Gatteño
  #77
Old 04-01-2020, 11:32 AM
lesbrunn's Avatar
lesbrunn lesbrunn is offline
C) something else?
Try ticking the routing option in the new track dialogue.
MSI Pro Z790 Edge | i913900k @ 5.7GHz | 64GB DDR5 5600| 8TB NVMe | 3TB SATA SSD |10TB WD Black | Audient iD14 | PT 2022.12| Win 11 Pro | Tons of VIs and plugins
  #78
Old 04-01-2020, 11:33 AM
EGS's Avatar
EGS EGS is offline
Folder tracks are cool. Good job AVID.
Click for audio/video demo
Click for resume
  #79
Old 04-01-2020, 11:45 AM
andystar andystar is offline
anyone else with crashes on Import Session Data if plugins missed?
  #80
Old 04-01-2020, 11:51 AM
neilvg neilvg is offline
So I love the new folder tracks in terms of functionality, but I HATE how it looks. My beautiful color coded sessions looking 'garish' with fat lines and bright colors that can't be toned down.
I hope they update with some visual aesthetic features. Since so many of us will now use folder tracks regularly, I think it should look better than the current integration. I can understand why they want them so bold, but I think its eventual ubiquitous use in sessions will deem this look a little overkill. At least some visual preferences would give us the option to tone it down.
Otherwise, I think it's great, easy to use, and awesome for my workflow.
Pro Tools 11.2.1 | HDN | OSX 10.8.5 | oMP 12-core 3.06 16gb 1333 DDR3 | 128gb Corsair Force SSD System | 256gb Asus RAIDR PCIE SSD Project | 2tb WD Samples drives
30" Cinema Display | Adam S3a and Dali MS-4 with Krell KAV-400xi amplifier | Lynx Aurora HD interface w/ Cranesong Spider via AES
Pro Tools 2020.1 off the wall Pro Tools 2019 141 11-28-2022 01:59 PM
2020 PT-Release belasoul Post - Surround - Video 6 03-10-2020 03:17 PM
New Avid Link 2020.1 - launched today 1/16/2020 marianna Licensing & Accounts 8 01-16-2020 11:43 PM
Does anyone use XV-5080 or XV-2020? Atana 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 10 09-24-2002 10:52 PM
