Has anybody used 3rd party virtual mixing consoles as front-end for lower latency?
For a totally native system, (running HD Native in my case) the idea of the UA or Waves console has me thinking that even if an interface doesn’t offer external DSP, that some virtual console running a single verb or processing plug-in could be a low-latency solution for recording one or two tracks vs. trying to set Protools’ buffer to a lower setting, especially once you’ve already been making mix decisions and the CPU load is getting higher. So using a program like some of the ones I’ve listed below might allow you to monitor your input with some simple effects on it at a low buffer setting, basically giving you a virtual signal split so you can monitor it before it goes through the PT mixer. I’m not quite sure what the interaction would be between the 3rd party software and the HD interface, but presumably I could still monitor all my in-the-box stuff from the normal stereo out, I’d just have to mute the output channel of the record track and listen to it coming from the “console”.
This is all in the hopes I could use the monitoring from the 3rd party app at least at a 64-128 setting, while the PT session chugs along at 512-1024 maybe. Here are the links to various apps I found: https://www.macworld.com/article/302...r-devices.html https://www.kvraudio.com/product/voi...er-by-vb-audio (that last one is for Windows, but I like that it looks dead simple, and maybe is light on CPU). I’m on a Mac http://cdm.link/2011/02/the-79-virtu...rrison-mixbus/ This also brings up the idea of SoundFlower, but apparently that app is no more… Any thoughts? Something I’m missing? Thanks
HD Studio, PT2022.6, UA Apollo x6, 2018 MacBook Pro, 32 Gig, Big Sur |
Re: Has anybody used 3rd party virtual mixing consoles as front-end for lower latency
Presumably you could configure a whole other DAW to do this, but you'd still need some 3rd party pipe solution like Jack, which looks like it's built into the Harrison app. It also seems like something simpler and more dedicated to this task wouldn't use as much CPU.
Also to be clear I'm only talking about using it as an input chain. Also I'm not talking about regular plugs like Slate's "Virtual Console" to emulate the sound of a console. I mean an actual separate app acting as a physical console just to monitor input before it hits the PT mixer....
You need an FPGA mixer to do something like this and be actually useful. RME's TotalMix, UA's Console, MOTU CueMix DSP, Antelope's mixer, etc. run on the audio interface hardware to route back without going through buffers for things like this. Why they are advertised as zero latency monitoring.
The minute you go through a buffer, you might as well be doing it directly in Pro Tools. The latency of a loopback has already been added. At that point, use a different DAW than Pro Tools to record if there is one that goes lower for your system. No point in mucking with two -- then take the audio afterwards, import it into Pro Tools and mix in Pro Tools.
Pro Tools Ult 2024.3.1, HDX 2, MTRX/SPQ, RME BBF Pro + MADIface Pro • S1 x 2, Fire Max11 x 2, Dock, iPad Air5 • Mac Mini 14,12, 12 core, macOS 13.6.6 • RAM 32GB, SSD 4TB, GPU 19 core • QNAP TVS-872XT 148TB TB3 |
RME's TotalMix FX is great for this, plus you get a great interface and rock solid drivers.
Yup. I use TotalMix for almost all tracking/cue mixes. It's really flexible with EQ, comp, reverb/delay as well.
I7-4930K, X79-Deluxe, 2133 32 GB, GT640, 512GB 860 Pro, 1TB Evo, WDB 2TB X2, Win 10 Pro, PT Ultimate 2020.12 Studio One 5 Pro, REAPER 6 RME, Daking, Heritage, ISA, Sytek |
Can't lower the buffer size for HD Native & Omni with 3rd party DAWs? | akhafaji | Pro Tools HDX & HD Native Systems (Win) | 3 | 05-27-2014 05:24 AM |
For those who don't use mixing consoles / etc | theaero | Pro Tools TDM Systems (Mac) | 4 | 08-18-2009 04:13 PM |
Need Lower Latency! | spartikus | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 05-16-2009 07:03 PM |
Mixing in Protools vs Consoles - Mix Magazine May 2002 | usinare | Pro Tools TDM Systems (Mac) | 113 | 05-24-2002 12:53 AM |
Anyone mixing on Mackie 8-bus consoles? | PwAg | General Discussion | 7 | 06-08-2001 08:35 AM |
