Re: Ewql play-
Composer/Sound Designer Pro Tools 11 HD, 64Gb ram, 12tb SSD, 1909 HD Omni/Thunderbolt Native A bucketload of libraries www.Reverbnation.com/jedediahjenk www.soundcloud.com/jedediahjenk notedmusic.wix.com/jedediahjenk Last edited by notedmusic; 12-18-2014 at 02:34 PM. |
Re: Ewql play-
Try doing offline one track at a time and see if that's okay. If it is then that would say Play is NOT the issue. Are you using one instance of Play with one instrument or multiple instruments in a single instance of Play? The only time I use multiple instruments in a single Play instance if I am using different articulations of the same instrument (say trumpet).
Offline/online - no problem. This might well be something with your system. |
Re: Ewql play-
I'll get this with only ONE play instance believe it or not and offline CRAWLS to 0.7% ??!! But then it's out of sync... So I'm stuck. And constantly bouncing out offline is no way to compose. UPDATE: Oddly enough I was able to offline bounce a passage that could throw the error in realtime... Odd. But I still have the syncing/delay problems that come with offline (I hven't even touched that yet- I have too many issues already with CPU).
Composer/Sound Designer Pro Tools 11 HD, 64Gb ram, 12tb SSD, 1909 HD Omni/Thunderbolt Native A bucketload of libraries www.Reverbnation.com/jedediahjenk www.soundcloud.com/jedediahjenk notedmusic.wix.com/jedediahjenk |
Re: Ewql play-
Re: Ewql play-
I have a system that's way less powerful than yours and I have yet to have the problems you say you're having. I'm working on a score for In The Hall Of The Mountain King and some of the strings parts get very frenetic/dense (try 32nd notes and then some) and my system is barely breathing hard. |
#16
Re: Ewql play-
HD 11.3 seems a tiny bit better but I've still had this error in online playback for no obvious reason at all, when CPU usage is still minimal. I've not been very successful to date with 32nd notes... this sucks. What engine setting are you using in PLAY?
#17
Re: Ewql play-
Just for the record 11.3 didn't solve this for me.
#18
Re: Ewql play-
I still get this error with 90% CPU left over, especially when adding new instruments during playback or randomly during playback.
#19
Re: Ewql play-
Is it supposed to break every time I add a new instrument even with 90% free CPU?!
#20
Ewql play-
I haven't installed the new ProTools update 11.3 yet. Uninstall your current Play engine/update - then reinstall it.
A Rig: MacBook Pro Spring 2013, 2.8Ghz I7, 16GB RAM, OSX Mavericks 10.9.4, PT 11.2, MBox Pro 3, Glyph GT 050 Qx3 1.5 TB drives Thunderbolt-FW400, Presonus Faderport. 10 REMOVED! B Rig:MacBook Pro Spring 11, 2.33 GHz I7, 16GB RAM, OSX Mavericks 10.9.4, PT 11.2, MBox Pro 3, Glyph Portagig 62 portable 1 TB drive Firewired with 400, Presonus Faderport. 10 REMOVED! I am the main songwriter/performer for Midwest Whitetail, Cabela's Deer Nation, Spring Thunder, and Northern Waters Series! |
EWQL Play 4 AAX 64 | jryser | AAX Plug-ins | 7 | 08-26-2013 04:00 PM |
EWQL Play 4 is AAX for PT 11 | jryser | AAX Plug-ins | 59 | 08-02-2013 10:33 AM |
OSX Lion, PT9.0.5 and EWQL Play | paulrgmusic | macOS | 0 | 08-19-2011 10:23 AM |
EWQL new Play version | Ludia | Virtual Instruments | 6 | 05-12-2010 09:49 PM |
Anyone using EWQL PLAY in Pro Tools? | dubaifox | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 10 | 10-04-2008 07:15 AM |
