Old 02-01-2013, 02:25 AM
pmcminn pmcminn is offline
Default Difference between Duplicate and Consolidate in Pro Tools 7?
Hi -
Quick query that I couldn't find a google answer to...
For the work I do I need to prepare duplicated WAVs using the Audiosuite > Duplicate tool. As there's no shortcut for this function, I was wondering if consolidating regions into one 'wav' file is exactly the same? There's obvs a shortcut for this and would speed me up loads.
Any ideas?
Thanks in advance.
Old 02-01-2013, 02:34 PM
Emcha_audio's Avatar
Default Re: Difference between Duplicate and Consolidate in Pro Tools 7?
Duplicate will do just that. Duplicate the same clip. Consolidate is taking all the selected clips on a track and make one big clip instead of multiple little ones. *Coughs* Just saw you were still on 7 so that's duplicate regions / consolidate regions
Manny.
Wave-T.com
Old 02-07-2013, 06:28 AM
Thanks for this reply....
But -
If you select a number of regions and Audiosuite>Duplicate, you can create one continuous file as you described as 'consolidating'...
Is this the same as the Consolidate function?
Thanks.
PT10 duplicate/consolidate and fades... Nowhereman macOS 1 04-17-2012 12:48 AM
Consolidate and Duplicate function problems in PT LE 7.3.1 piotr_s 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 08-18-2007 04:43 PM
Dumb question? repeat/duplicate any difference? moon1pulse 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 10-08-2006 01:20 PM
consolidate or duplicate ( continous file) a track cary chilton 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 10-03-2006 02:23 PM
Difference between duplicate plug-in and consolidate? dkrausz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 05-30-2002 10:15 AM
