Old 09-29-2005, 01:34 PM
gomi gomi is offline
Default Digi Core Audio Drivers + Max/MSP
Are these compatible? Cycling says they are. I am having a strange problem.
I know this isn't a Max Forum, but it's directly related to the Digi Hardware/Driver.
When I launch Max/MSP 4.5.5 and tell it to use the Digidesign Driver and my mBox/001/002 whatever
(I have all 3 here) I get distortion in the Audiotester. Now, I can get rid of the distortion
by upping the Vector IO and Signal Vector to 1024, and the Digi Buffer to Max... but the real
problem comes when Max "lets go" of the Digi Driver. The max engine turns on and off depending
on what you are doing. Now sometimes it lets go of the driver, and then it can grab on to
it again, and audio passes normally. But more often then not, Max will stop it's engine..
and then fail to start it again. Switching to Built In and manually quitting the Digidriver
does not help, this only causes Max to Crash.
I have tried version 6.4 6.5.2 and 6.9
Has anyone seen this?
Maybe the digi tech guys have?
I'm at a loss.
And yes I have contacted Cycling, but I have not heard back from them as of yet.
.. gord
.. www.vfs.com
.. sound design
Digi 002-using FW & core-audio drivers to output audio to mac WITHOUT using ProTools DaveZ 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 13 04-12-2012 12:53 PM
So how are the core audio drivers in 6.4? mike connelly Pro Tools TDM Systems (Mac) 0 05-03-2004 03:39 PM
Digi, where's 6.0.1 and Core Audio Drivers? lancejorton Pro Tools TDM Systems (Mac) 15 04-02-2003 02:43 PM
OSX drivers for Core Audio & Digi 001 audiomiditweaker 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 16 03-08-2003 12:17 AM
Digi CS...Will there be Core Audio drivers for 001 with PT X? Kamurah 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 09-27-2002 02:02 PM
