Old 09-04-2006, 03:20 PM
icenet icenet is offline
Default Current Playback Engine
I usually get the message "current playback engine is 1DSP/Med Voices, would you like to use the saved playback engine" when I open someone else's PT session. I have an HD2 system. Can someone explain this to me? Does it really matter if I use the current or saved palyback engine?
Thank You.
Old 09-04-2006, 04:03 PM
Drew Mazurek's Avatar
Default Re: Current Playback Engine
Typically you'll want the DSP to be allocated the same way it was when the session was last saved and presumably working well. Unless you have a specific reason for altering it (say it's set to 96 tracks over 4 DSPs and yet it's 24 track session and you want more DSP for plugs) I'd leave it alone.
www.drewmazurek.com
Old 09-04-2006, 06:23 PM
Thanks for the info. Now if change the session to only 1DSP(less than original) and need more, won't PT do it automatically?
Old 09-04-2006, 06:34 PM
robstaman robstaman is offline
no
Playback Engine>Current Engine issue Hunterkiss macOS 0 06-28-2013 01:14 PM
No m-audio interface in current engine (playback engine) SlicerSounds Windows 1 10-04-2012 12:27 AM
Can't initialize current playback engine PT 9.03 LE mzkguy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 09-12-2011 06:31 PM
Pro Tools could not initialize current playback engine. mclilmack Pro Tools 9 1 08-28-2011 01:49 PM
Current playback engine... Gonk Pro Tools M-Powered (Win) 0 04-28-2010 01:55 PM
