Old 05-05-2015, 03:13 AM
andycopeman andycopeman is offline
Default Reason rewire not working in PT12
Hiya,
I recently upgraded into a brand new MacBook Pro with al the trimmings.
I used to use PT10 with Reason 5 (and before that PT 8, 7, 6 etc and Reason 3) with multiple reason audio channels coming into sessions, driven by midi from PT.
I now have PT12 and Reason 8 in Yosemite.
Reason does not come up in my instruments list in the PT inserts. Waves rewire does come up, so Rewire must be working to some degree.
Reason comes up beautifully as a fully-functioning rewire companion to Ableton Live 9 ... so Rewire must be working from Reason's end of things.
I have read of numerous instances of Reason/PT rewire difficulties on this forum, but the symptoms seem to be different to mine.
Can anyone help me here? I assume that both PT12 and reason 8 are 64-bit, so there should be no incompatibility there. Many postings suggest opening the "get info" window on the Reason app icon and forcing a bit depth. I get no such options.
Is there something missing? Any suggestions will be received with deep gratitude.
thanks
Andy
Maleny
Queensland
Old 05-05-2015, 04:34 AM
musicman691 musicman691 is online now
Default Re: Reason rewire not working in PT12
Yes PT12 and Reason are 64 bit but Reason has to be set to run as 64 bit. The Mac version of Reason actually has both 32 and 64 bit support from the same install. With Reason closed right click on the Reason icon and select 'get info'. When that window opens check for the state of the checkbox that selects whether Reason runs as 32 or 64 bit and make sure it's set to run as 64 bit. Do this and you should be good to go.
Word of warning: I don't have PT12 but PT10 and PT11 but when I use Reason rewired into PT AND I'm using a patch in Reason that has a Combinator I can't use a single MIDI path into Reason. I have to use two - one for MIDI cc7 (volume) and a second for everything else MIDI. This is with Reason 7 and maybe they fixed this in R8. If I don't use a Combinator in Reason only a single MIDI path is needed between the two programs.
Old 05-05-2015, 08:48 AM
Top Jimmy's Avatar
It's also a known issue that newly installed Rewire apps won't show up in Pro Tools until the plugin cache is trashed and Pro Tools has to scan a rebuild it.
Follow the instructions for 11, it's the same with 12.
http://www.sweetwater.com/sweetcare/...s-preferences/
James Cadwallader
Hackintosh - Gigabyte Z77X-UP5TH, Intel Core i7-3770K, 32GB 1600Mhz DDR3, 2x SATA 6Gb/s 240GB SSD, 3x SATA 6Gb/s 1TB HDD, 1x Glyph 2TB USB3 HDD, Sierra 10.12.6.
Pro Tools HD 2018.12, Focusrite Red 8Pre, Mbox 3 (Mac)
Pro Tools 11.3.2, Mbox2 (Win 7)
Old 06-04-2018, 09:10 AM
littlesicily littlesicily is offline
Running Reason 8.3.2d7 build 6323 and when I Get Info on the app there's no checkbox for 32/64bit. There's also no rewire plug in my PT plugins folder.
Wonder if this version of Reason doesn't work in OSX 10.13.3
PT Ultimate 2018.12, HD Native TB, HD I/O 16x16 x2, Mac mini 2018 3.2GHz 6-core, OSX 10.14.2, EuControl 3.7 w/ Avid S3, UAD-2 TB octo
Old 09-03-2018, 05:38 AM
That could well be it. Reason 8 is way old. You're going to have to upgrade to Reason 10.
Rewire Reason 6.51 to PT9 not working? lwilliam 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 08-30-2012 11:52 PM
Reason 4 + 002 not working in Rewire mode. DJ Hellfire 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 31 08-23-2010 12:25 PM
Pro Tools LE and Reason 4 w/ Rewire not working. cringe 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 06-12-2008 01:28 PM
Reason/REWIRE not working in PT 6.1.2 thumbolt68 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 07-19-2006 02:21 PM
Reason working in standalone, but not with ReWire. pedrohead 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 11-19-2003 05:56 AM
