Go Back   Avid Pro Audio Community > Pro Tools Hardware > Third Party Interfaces
Old 05-10-2018, 08:05 PM
jgerards jgerards is offline
Default Pro Tools and multiple interfaces?
Will Pro Tools recognize multiple interfaces at the same time via separate thunderbolt ports? For example, I have an Apollo 8p, a Focusrite Clarett 8pre, and a Focusrite Scarlett Octopre. I would like to run the Octopre into the Apollo via ADAT and then run the Clarett into the other thunderbolt port on my MacBook Pro. I'm running Pro Tools 12. Is this possible? Thanks for any input?
Jeff
Old 05-10-2018, 11:41 PM
BScout BScout is offline
Default Re: Pro Tools and multiple interfaces?
Octopre into Apollo: Pro Tools won't care because Pro Tools only needs to talk to the Apollo. So this will work.
Apollo + Clarett will require making an aggregate audio device and then having Pro Tools talk to the aggregate. That's if you are on a Mac.
If you aren't on a Mac, it's not possible.
Pro Tools, on its own, will not talk to more than one audio device at all. It's up to something else to make more than one audio device appear as one device (Aggregate CoreAudio for Macs, in this case.)
The connection type doesn't matter (thunderbolt, firewire, usb) when you make an aggregate audio device.
Pro Tools Ult 2018.12, HDX 3, MTRX/SPQ, HD OmniMac Pro 5,1 - 3.06 GHz 12 core - macOS 10.12.6RAM 64GB, SSD 4 x 2TB, GPU GTX 980 4GB
Old 06-23-2018, 03:14 AM
Fredrik Jansson Fredrik Jansson is offline
"Apollo + Clarett will require making an aggregate audio device and then having Pro Tools talk to the aggregate. That's if you are on a Mac."
How do you do this?
I want to use my 003 as Control Surface with my Apogee Symphony as interface.
Old 06-25-2018, 12:41 PM
junkgear's Avatar
junkgear junkgear is offline
How do you do this?
Use this Apple Support Article to help you create an aggregate audio device.
Once created, start Pro Tools, and change the playback engine to use your new aggregate audio device. The name will show up as whatever you named your aggregate in the steps above.
Will K
System Details
Pro tools 10 is compatible with multiple audio interfaces? elsanto Pro Tools 10 6 01-17-2015 12:48 PM
Will Avid ever update Pro Tools so you can use multiple interfaces again? Doddethy Pro Tools 10 6 06-18-2013 11:14 PM
multiple interfaces with Pro Tools 8 montelee Pro Tools M-Powered (Mac) 7 01-06-2013 10:29 PM
PT 9 and Multiple Interfaces mhelm01 Pro Tools 9 25 12-03-2010 09:46 AM
Multiple interfaces on a Mac nz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 10-14-2005 10:23 PM
