Old 12-21-2020, 04:20 AM
PH68 PH68 is offline
Default No option to use WASAPI
Does PT still support WASAPI?
WASAPI works perfectly well with any programs on my PC (MS Surface Book) that can use it.
However, I get no options to use WASAPI with ProTools 2020, even when opening PT and pressing N.
ProTools ~ Reaper ~ Arturia ~ Eventide ~ iZotope ~ Spitfire ~ MS Surface Pro
Old 12-21-2020, 06:59 AM
junkgear's Avatar
junkgear junkgear is offline
Default Re: No option to use WASAPI
As far as I know it still does. I remember there were some sharing issues between PT and Windows, so you may want to disable the audio device in Windows so that it doesn't use it, then try and launch PT while holding the N key down and see if that makes a difference.
Will
System Details
Old 12-21-2020, 07:06 AM
Hmmm, the last time I used that, it was as easy as right-click on the PT icon and there was an option to run WASAPI. Now I don't see it(but haven't tried that in well over a year). Maybe a mod could check on this?
Old 12-21-2020, 10:36 AM
junkgear's Avatar
I can check, but neither of you have an option for Windows Audio Device in the Playback Engine? That is the WASAPI device.
Will
System Details
Old 12-21-2020, 11:40 AM
Bob Olhsson's Avatar
Bob Olhsson Bob Olhsson is offline
It was always limited to motherboard audio.
Bob's room 615 562-4346
Interview
Artists are the gatekeepers of truth! - Paul Robeson
Old 12-21-2020, 03:36 PM
I can open other software (such as Adobe Audition) and select WASAPI with no problems, so it's clearly not a driver issue.
I've tried opening ProTools and pressing N.
I've tried Run As Administrator.
No matter what I try, PT does not let me get beyond the "Unable To Locate Hardware" message on start up.
Bit annoying really.
Wasapi PH68 Pro Tools 2020 0 12-16-2020 10:07 AM
MP3 Option-Demo Expired-No option for aut. code desdichadisimo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 10-10-2006 01:24 PM
HD with AV Option XL digiengineer Pro Tools TDM Systems (Mac) 2 07-18-2002 07:24 PM
AV Option or AV Option XL with Transoft Fibre potatohead Post - Surround - Video 5 08-06-2001 10:24 AM
AV Option Fan required for AV Option|XL too? Samhein Post - Surround - Video 3 08-29-2000 05:45 AM
