Old 08-20-2002, 10:17 AM
myrios myrios is offline
Default Midi: can\'t record midi notes synth input
It seems like I've got it all set-up right: OMS 2.3.8 with Midisport 2x2: In-A/Out-A going to a Korg M1 Out/In. The Thru of the M1 is going to 2 other modules. The My Studio Setup tests properly. I can import midi tracks and they play on all synths that are connected. If I set the Midisport to MidiThru, the keyboard does control the modules.
But: when I create a new Midi track and choose to record on that track, and set the Midisport to USB, the M1 makes no sound, nor do the modules receive any midi input. I've got my Input Devices... set to the M1 (It also shows the Midisport, which I've tried setting to, but this option does not have any channels to choose from and still no notes heard or recorded). I've tried all channels with the M1 chosen as the Input Device.
I think that explains everything I've tried...
Anyone have any ideas?? It seems like when I set the Midisport to USB, the keyboard signal is not passed to Protools.
myrios
Old 10-03-2002, 10:59 PM
dman dman is offline
Default Re: Midi: can\'t record midi notes synth input
myrios, did you ever get an answer or figure it out? I've got the same problem, can't read my midi keyboard, even though my Finale program reads it just fine through the normal interface. Dman
HTML code is On
Recording Midi notes and keeping existing notes during record Sherbert99 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 09-15-2008 09:40 AM
Is it possible to record MIDI notes without a MIDI Keyboard? pianoman_78 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 12-27-2007 06:13 AM
Record MIDI track Then Record Again To Add Aditional Notes + JCWarrior Tips & Tricks 5 04-13-2007 03:51 AM
002 will not record midi notes sent from my mpc? starvinboi 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 05-05-2005 12:50 PM
synth (virus c) stops playing midi notes from PT toreys MIDI 0 09-07-2004 04:28 PM
