Old 10-31-2013, 01:44 AM
JohnTrue JohnTrue is offline
Default Weird issue with Kontakt 5 & controller keyboard
Hey folks, I'm new around here and could use some help. I'm trying to use Kontakt 5 through pro tools and it won't recognize my midi key strokes on my Impulse 49 controller.
Specifically what I mean is this - I load kontakt as an insert in pro tools, load my instrument, and when I try to play nothing responds. I can click the keyboard on the screen and sound comes out. What is MUCH stranger to me is that my automap control nobs work on the keyboard, I can control my sound, chord, key, scale, etc knobs FROM my controller keyboard, but I can not use the actual keys to make sound. My midi works when I use reason and other programs as inserts, but not Kontakt. Also, Kontakt recognizes my keyboard when it is in stand alone mode not used as a pro tools insert.
Does anyone have ANY ideas? I've tried using a different keyboard, changing my midi insert channels, using different USB cables, and a host of other things I'm to tired to think of right now. But nothing is working for me.
I was supposed to finish up a project tonight but because of this issue I've been unable to get anything done on it.
Thanks for any help in advance!
Old 10-31-2013, 02:06 AM
Glenjb Glenjb is offline
Default Re: Weird issue with Kontakt 5 & controller keyboard
Just a double check here.. are you record enabling the instrument track? thats assuming you are using kontakt on an instrument track...
also double check the midi channel input in the kontakt instrument gui... choose omni to be safe while you are sorting this maybe..
..cant think of anything else right now i'm tired too :)
Old 10-31-2013, 07:57 AM
Emcha_audio's Avatar
There's also the midi controller button that you can check, if it says all you could change it to your controller (assuming that it is set in the midi instrument setup) and make sure that you see that it is routed to the actual plugin, you should see kontak 5-1 (if it is the only instance of kontak you have). If that is greyed out, you need to actually switch it to the kontak 5-1. those are viewed when the Instrument tab is checked in the View options for edit and for the mixer window.
Manny.
Wave-T.com
Old 11-01-2013, 06:12 PM
Do you have PT set in preferences to sue the first selected MIDI instrument? What type of track are you inserting Kontakt on? Do you have the correct MIDI channel selected in the Kontakt instrument? Set it to Omni and see what happens. To debug your system I'd try things in standalone mode and if that work then work with PT.
Jack
QAPLA!
Old 11-03-2013, 06:45 PM
Hey guys - thanks for the help! I still have NO idea what was wrong, but the issue has resolved itself. I came home on Friday and went to get it working and everything just worked flawlessly. It just took a few days of being unable to do anything...
Home built Windows 8 Machine
16gb of ram
Intel i5 Processor
Impulse 49 controller keyboard
Pro Tools 10
Weird issue with MIDI controller recognition js_nyc Pro Tools 11 3 03-03-2014 11:09 AM
weird crash issue PTx and possible procontrol issue, need help Cryos Pro Tools 10 5 12-08-2011 05:17 PM
Weird pro tools issue...or user issue stereojunk 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 09-30-2010 07:03 PM
Kontakt Pro Tools Midi Controller Signal Routing jussounz Pro Tools M-Powered (Mac) 2 02-20-2009 05:10 AM
use the controller keyboard as a tone module too, or just as controller? Joseph Anderson 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 02-08-2002 12:01 AM
