Old 12-25-2010, 02:28 PM
usastra usastra is offline
Default How can I export my plugin mappings and defaults?
I installed PT9 on a separate system, but now I lost all my plugin defaults and plugin mappings.
Is there a way to import these from my other system?
Old 12-25-2010, 02:35 PM
KingFish KingFish is offline
Default Re: How can I export my plugin mappings and defaults?
Yes...
1. BACKUP CURRENT FOLDER (even if it's all default Settings) ~/Library/Application Support/Digidesign/Plug-In Settings
2. On your old system, navigate to ~/Library/Application Support/Digidesign/
3. Copy your "Plug-In Settings" Folder
4. On your new System, drag the "Plug-In Settings" Folder into ~/Library/Application Support/Digidesign/ and select "Overwrite" when prompted.
Anything goes wrong, trash the folder, and restore the backed up folder.
David
- MacStudio M1
- HDX II Sonnet xMacStudio
- 16x16 HD i/o x 6
- PT ULTIMATE
- SONOMA
- ProTools Dock / S1 / Control App
Old 12-26-2010, 12:47 PM
crizdee's Avatar
crizdee crizdee is offline
Unless you have saved your plugin custom maps!! you won't be able to import them into your new system.
If you can still accessa your old system then open a plugin with "view maps" enabled and select export all maps, then on the new system import all maps etc.
Chris
Producer, Engineer,
www.ukmastering.com
How to export a plugin list garnoil Post - Surround - Video 9 11-24-2022 03:59 AM
mp3 export defaults... mhender Pro Tools TDM Systems (Mac) 15 06-23-2011 05:01 AM
FR - AIR instrument MIDI mappings remute Virtual Instruments 13 01-10-2009 09:44 AM
How to set Mp3 plugin defaults? jccrtv 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 09-20-2006 09:00 PM
fader mappings pleasedonthitme MIDI 0 05-02-2003 09:25 PM
