Old 07-22-2007, 11:32 AM
dcolman dcolman is offline
Default Sync IO start up problem
I am running an HD system with a sync IO and a 96IO on a G5 Dual 2.3
The system is running fine once it is all powered on and launched. However over the last few week I've started to get a problem with the sync IO when I power on the room. It comes up with the ring around the power button orange, and won't turn to green and show the timecode until the computer has been on for about 10 minutes. This started as just an occasional thing, and only lasting for a minute or so. Now it is every time I come in in the morning. It is acting like a car that needs to warm up. Restarting the interfaces and the computer don't do any good.
Thoughts?
Old 07-23-2007, 04:47 AM
priorytools priorytools is offline
Default Re: Sync IO start up problem
Try changing the serial cable first. . .
And of course check it's seated well into the core card. . On the core card it needs to be plugged into the socket closest to the digilink socket.
~ 2019 Rack Mac Pro 3.2 GHz 16 core 384 GB RAM Catalina 10.15.7 / Pro Tools Ultimate 2022.12.0 / HDX 2 + UAD2 PCIe OCTO+QUAD / HD I/O's x 4 + 1 x 96io / Digidesign Pre's x 3 / Avid S6 M10-24 -V22.12.1.34 ~
~ Mac Pro 8 core - clover - 13 GB ram - 10.6.8 / HD5 / Pro Tools 9.0.6 / Magma PE6R4 ~ ARCHIVE RIG
~ Mac Pro (Early 2009) - 2 x 2.26 GHz Quad-Core-32 GB RAM-10.13.6 / Pro Tools Ultimate 2019.10 / Apollo 16 / Avid S3 ~
Old 07-23-2007, 07:44 AM
Magnetic Magnetic is offline
We're having the exact same problem on one of our HD systerms. The other identical system works fine. We've swapped the serial cable with no effect.
MacPro 8-core 3-gig w/5-gig RAM
HD1 w/192 & Sync I/O
PT 7.3.1cs3
dCommand
MacOS 10.4.9
Old 07-23-2007, 11:25 AM
Craig F Craig F is offline
have you tried re-flashing the firmware?
other than that sound like component failure
Thank you,
Craig
Old 07-25-2007, 08:54 AM
I tried the firmware and the cable. No luck there.
Old 07-25-2007, 10:10 AM
get in touch w/ Digi Tech support
you'll probably need to send it in
Thank you,
Craig
Old 07-25-2007, 09:59 PM
ok thanks
Sync I/O start up messages/codes??? Armando Pro Tools TDM Systems (Mac) 4 02-05-2014 12:25 PM
PT 10.3 start up problem rory13 Windows 4 10-18-2012 02:49 PM
Problems with song start, click track, and sync Tbob 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 06-16-2010 06:26 PM
Random start point when recording using sync (MMC) Mark ' Em 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 04-24-2008 03:08 PM
start up problem Hendrik Pro Tools TDM Systems (Mac) 0 04-20-2000 01:45 PM
