Is this a Core Audio problem?
I'm running PT 6.2.2 on a PowerMac G4/867 with my Digi 001. Everything is fine as far as audio playback, except I also use Final Cut Pro 4 and it plays back through the G4 speaker instead of the Digi. This used to work before I upgraded my PT software. Is this issue related to there not being a standalone Core Audio app for my situation yet? I have my system prefs set to playback through the digi, however i don't have a core audio app that will let me configure FCPro. Also, if this is the case...when will the new Core Audio standalone be out? Next year? |
Re: Is this a Core Audio problem?
arhatsoul,
I would do this first: Make sure Digidesign HW (001) is the Default Output in your Mac's /Applications/Utilities/Audio MIDI Setup. Make sure FCP 4 is a Supported Application in your Digidesign CoreAudio Setup. If not, just Add New Application and select the FCP 4 app and then click Done and Done again. If it still isn't working, then we can pursue other troubleshooting.
ant'ny ------ QS 2002/933MHz, OS X 10.3.8, 1.25GB RAM, Two ATA HDDs, Two 17" Studio Displays, Digi001-PTLE 6.4, Reason 2.5, DP 4.12 |
PT 7.3.1 Core Audio problem | innesireinar | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 01-17-2007 12:33 PM |
No audio from Apple Apps. Core Audio problem? | Armando | Pro Tools TDM Systems (Mac) | 10 | 10-23-2006 06:03 AM |
Help? Core Audio problem? | Archmart | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 12-19-2005 09:43 AM |
CORE AUDIO PROBLEM... | tomhartman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 05-07-2005 08:48 PM |
HD core audio problem | ndlsd | Pro Tools TDM Systems (Mac) | 5 | 03-31-2005 04:29 PM |
