Old 06-15-2015, 03:29 AM
InquisyThorr InquisyThorr is offline
Default ProTools 11HD hangs on startup - Xpand
Hi there,
I have a PT11HD, which i'm using on both Windows 8 and OS X MAvericks.
On Windows, my ProTools now freezes during startup on Xpand loading.
I tried reinstall the Air VI package, but still the same issue.
Anyone knows how to reseolve that thing? (which appeared out of nowhere, without any upgrades done prior to it or such thing)
Thanks in advance
Old 06-15-2015, 04:06 AM
stickboymusic stickboymusic is offline
Default Re: ProTools 11HD hangs on startup - Xpand
Assuming you can get protools to open? If not hold down shift when opening the program and it will bypass plugins
Once open go to setup/preferences/operation and make sure your user library is set to the correct place where all your xpand instrumets/presets are.
If this doesn't fix it then im out of ideas.
Old 06-15-2015, 04:54 AM
Hi;
Thanks for the reply
I tried to remove Xpand from the AAX plugins folder, so it won't be loaded to see if Xpand was the cause, but now, it freezes on the next one (which is XForm)... It has already external plugins like Waves and Flux, so I don't know who to blame... ProTools I guess, but don't know what to do next...
Tried to trash prefs, still no luck...
Any help is appreciated :)
Thanks in advance,
Charlie
Old 06-15-2015, 05:31 AM
Maybe try going to add/remove programs and "repairing" pro tools
HELP! PT Hangs Up On StartUp. Steve@ZooWest Pro Tools TDM Systems (Mac) 5 05-22-2010 12:15 AM
Pro Tools 8 Hangs on startup T666 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 12 08-07-2009 08:56 AM
ProTools Session Hangs on Startup and LiquidMix kafka Pro Tools M-Powered (Win) 1 06-24-2008 07:06 PM
Help: ProTools hangs on startup JTMoring 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 01-19-2007 09:41 AM
5.0.1/G3 B&W Hangs @ StartUp!! DFatz1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 14 07-17-2000 01:07 AM
