Old 02-19-2016, 01:39 PM
pistonsvox pistonsvox is offline
Default S6L Virtual Soundcheck
Hi There!
Im having a bit of an issue connecting my Protools for virtual soundcheck..
(Macbook Pro running Yosemite and Protools 12)
So far i've connected the Cat5 to the surface, went into Audio/Midi Setup and Selected the AVB E6L setting so it shows up in my audio devices.
My Protools playback engine is the E6L.. and I've defaulted the I/O paths etc..
Output's from each channel are One for One, and I've patched the inputs from protools on the S6L.
Is there anything extra i'm missing that should be installed?
Cheers :)
Old 02-19-2016, 04:30 PM
hugolarin hugolarin is offline
Default Re: S6L Virtual Soundcheck
Your setup seems just fine. Have you had any luck before? Did you try to record instead of playing back? (Trying with a clear showfile that will be routing the stage inputs directly from the stage rack)
Old 02-19-2016, 04:38 PM
(clear console, ensure AVB E6 is connected, assign the stage rack and then start you protools with selecting E6 as the playback engine
Old 02-20-2016, 01:44 AM
Valentyn Valentyn is offline
Just for completeness: did you do a VenueLink setup?
And what exactly is not working? Audio should start working as long as you chose AVB in playback engine. Control features and "create session from VENUE" require VenueLink.
Old 02-20-2016, 05:10 AM
Hey! Cheers Will try again now, nope not doing Venuelink.
Old 02-20-2016, 05:24 AM
All working. Cheers guys!
S3L virtual soundcheck with Pro Tools 10? jacko VENUE Live Sound Systems 3 09-08-2014 12:45 PM
Can an SC48 do Virtual Soundcheck? LanceK VENUE Live Sound Systems 0 03-16-2014 06:39 PM
Advice on PC for Virtual Soundcheck Scott Fahy VENUE Live Sound Systems 1 01-06-2011 04:19 AM
Video into PT for Virtual Soundcheck? SimonInAustralia VENUE Live Sound Systems 11 03-26-2010 05:17 PM
Virtual soundcheck tom42107 VENUE Live Sound Systems 13 01-07-2009 08:08 PM
