peak meters on rec track dont work during playback
ive noticed something in PT thats kind of limiting. when im setting up to record i can use the peak meters to make sure my signal isnt clipping. as soon as i start normal playback to warmup or practice before laying down the actual track the peak meters no longer respond. but if im recording they start to work again.
is their anyway to see your peak meters on your record enabled track during normal playback ACK
2.0GHz Intel Core 2 Duo + 2GB RAM el-cheapo compusa generic firewire 80GB OSx 10.4.10, PTLE 7 (latest update) |
Re: peak meters on rec track dont work during playback
Thats because you're set to Auto Input Monitoring. Change it to Input Only and you will always see your meters.
Cliff Stendel -iMac 5K 32g
-PT12. HDX -HD I/O 8x8x8. -HD Omni -Avid S3 -API 2500 -API 5500 -UA 2-1176 -UA 2-610 -Neve 1073, Chandler LTD-1 -Eventide H8000FW -Lexicon PCM96 -Bricasti M7. -Joe Meek channel. -Waves Mercury, Flux all, Softube All, Plugin Alliance all, McDSP all, Sonnox All, MH production, Wave Arts,a bunch more -Moog Voyager XL, Nord Piano, Hartmann Neuron, ARP Axxe, Gibson Les Paul, Mesa Boogie Roadster, Kemper, Taylor T5 and T5-12 |
I answered this in your other post in another thread but, You want to select Input Only Monitor in Operations.
Bazzle |
It's also best to set your meters to pre-fader when recording and post-fader when playing back.
Cheers,
thanx all for the help. especially bazzle
you're welcome....I guess.
Signal peak/distortion/db meter peak when recording enabling track on Pro Tools LE 8 | hotgravy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 06-30-2012 10:49 AM |
Dragn n drop from PT track dont work | Eric Hector | Virtual Instruments | 0 | 03-14-2007 04:17 AM |
Peak meters accurate?? | mushmouth | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 05-05-2006 09:21 AM |
Meters--Peak or PPM? | danika | Pro Tools M-Powered (Win) | 0 | 10-15-2005 12:55 PM |
peak meters | dellamattia | Digidesign Hardware & Software | 2 | 03-27-2001 01:35 AM |
