Old 07-07-2019, 10:42 AM
SoundPark489 SoundPark489 is offline
Default ipad no longer shows in Surfaces
Hi all,
My Ipad Mini (An an Ipad Air 2) no longer shows up on the Eucontrol surface list. I only use an Ipad on occasion.
Eucon is enabled in Pro Tools 12 and I have an Avid Artist Mix which still shows up on the system and works fine.
The only factors which have changed since the last time I used my Ipad Mini (last summer) was my internet provider changed (thought I was assured my new provider had all the same specs) and I had to do a Windows reinstall.
I was wondering if any had any possible known causes for this or solutions I may not have thought of.
Thank you in advance.
Old 07-07-2019, 10:50 AM
EddieJones's Avatar
Default Re: ipad no longer shows in Surfaces
To clarify, is it showing in the surfaces tab in EuControl. Also make sure the version of EuControl matches the App
Sent from my HMA-L29 using Tapatalk
Old 07-07-2019, 10:53 AM
The ipad does not show in the surfaces tab, but my Avid Artist Mix device does.
The App and Eucontrol are both on the latest updates. Am I right to assume that would mean they match okay?
Old 07-23-2019, 03:27 PM
Any way to verify the wifi router? I have had them die out of nowhere
Old 07-24-2019, 12:50 AM
globaleric globaleric is offline
Quite likely the iPad doesn‘t „see“ the PC anymore because of one of the mentioned changes. Either the provider change involved getting a new router which is currently preventing that network connection for some (security?) reason, or the Windows reinstall involved a fresh PC Firewall setup currently blocking any incoming connections from the home LAN.
Or the iPad got a new IP address because of the router swap, which is now blocked by the Windows Firewall.
You could install the free „Net Analyzer“ utility on the iPad and then (while the PC is on) run a Scan on the LAN. The network connection between iPad and PC would only be ok if the PC appears in that result list.
Mac mini 2018, i7 3.2 GHz, 32G RAM, 1TB SSD
Mojave 10.14.6, PT 2020.5 Vanilla, several Waves V13 and some Massey plugins
PreSonus Quantum, Avid S1 & Control, MC Transport, Tascam HS-P82 Field Recorder
Pro Tools Control iPad app no longer working 19.5 efisch Avid S1, S3, Dock and Control App 3 05-10-2019 12:04 PM
Downloaded Soundflower Apollo no longer shows up! wedgewedge Pro Tools 10 0 04-10-2014 06:48 PM
Mbox 3 pro Just popped LOUDLY no longer shows firmware. Intuition FireWire & USB Audio Interfaces (Mac) 5 10-14-2013 11:28 AM
Plugin no longer on drive, but still shows up in menu in LE mathiasriffman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 06-11-2008 11:15 AM
CD on desktop no longer shows a volumn in OS 9.2 fifty8th1 Pro Tools TDM Systems (Mac) 0 08-24-2003 10:53 AM
