Old 07-09-2007, 01:35 AM
rune_sm rune_sm is offline
Default Reassign midi note?
Hey everyone
I'm getting MIDI signals from an electric drums set (Yamaha Dtxpress 2) into protools. My problem is, that it doesn't send the correct midi notes corresponding to my drum plugin (Addictive Drums).
Is there any way to reassign my incomning MIDI notes to another midi-note, so I don't have to change everything in my electric drum set.
For example, to play a kick my plugin recieves on channel 1, note C1 (36). But my electric drum set sends on another nothe. Can I reassign the incoming note to C1 (36) "on the fly" in protools?
Thanks
----- officially using the Allenstein --------
Old 07-09-2007, 09:37 AM
DigiTechSupt's Avatar
Default Re: Reassign midi note?
Unfortunately, there's no way to do this in Pro Tools currently.
Avid Audio Tech Support
Support FAQ
Old 07-09-2007, 10:19 AM
Stig Eliassen's Avatar
Depending on your PT version, you may be able to use MIDI real-time properties to transpose the notes on-the-fly. Will only work if the relative position between the MIDI notes coming from the kit matches Addictive Drums.
Drawn MIDI note length only staccato notes, regardless of note length kingofallwookies Pro Tools 11 2 02-07-2014 07:10 AM
Midi 101 really missing? Set high note/low note on track's input robinsonsdca macOS 4 11-10-2011 01:23 PM
Can you reassign midi data from one controller to another? Avi Bortnick 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 02-25-2010 10:26 AM
EXPORT MIDI from Stryke NOTE FOR NOTE... riggi Virtual Instruments 1 03-10-2008 07:32 PM
Please HELP - need to reassign midi notes for drum track funeral MIDI 0 02-05-2008 07:15 AM
