? Midi-track shorter than parallel audio-recording ?
Sorry for posting this highly specialized problem, but I count on the board's experience.
Setup: Live-recording of 4 singers + 1 stage piano, using an RME FireFace UFX II in standalone mode with its integrated "Durec"-function (recording directly from the interface to an USB-disc). 88.2/24 recording. Using: Microphones and line-level from piano Idea: to get a better piano-sound, I wanted to also save the piano's midi-data and replace the line-level piano-sound with a VI-piano from Pianoteq via the parallel recorded midi. Solution: since "Durec" cannot record midi data, I attached my iphone to the midi-out of the piano, recorded the performance on IOS "Nocturne midi recorder app", saved the midi data to my harddisc and imported it (together with the recorded WAVs) into ProTools. I really thought, by aligning the midi data with the piano-WAV, I could get a perfectly in sync midi-replacement of the microphone-recording. Problem: in no way, the midi was in sync with the recorded piano. The duration between the first and the last recorded note was way shorter with the midi than with the audio. Already within the first song, one can hear "the midi speeding away" .... Can you in any way imagine, why that happens? The only parameter, I can think of, is bpm, but both in the app as well as in ProTools, BPM was set to 120 (anyway, I do not think, that value has any influence, but I thought, I'd mention it...) So: thoughts, please, on how to correct this. Thank you! Last edited by dvdr; 07-09-2018 at 08:22 AM. |
Re: ? Midi-track shorter than parallel audio-recording ?
You can TCE the MIDI clip. Cut the MIDI at the first note, align it to the recording. Then, separate the last note/chord of the MIDI, and move it out of the way. TCE the end of the MIDI clip to match the audio, and then move the end note/chord next to it.
Makes sense?
Recording MIDI to Audio Track | wakemetal | Windows | 7 | 07-04-2018 06:44 AM |
recording midi to audio track | godzflava71 | Pro Tools M-Powered (Win) | 3 | 07-27-2009 07:04 AM |
Recording Audio from Midi Track | Cucaracha | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 12-04-2006 01:10 PM |
Audio track recording via midi triggering | tivdude | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 01-09-2005 06:20 PM |
Layer recording in an audio OR MIDI Track | ATLSteve | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 01-02-2003 06:24 PM |
