Old 01-16-2018, 06:52 PM
adam79's Avatar
adam79 adam79 is offline
Default Recording an Effect - 100% Wet
Is it possible to record the effect of any given plugin without a signal passing thru it? For example, adjust the settings of a plugin, record the effect it's creating (as an audio track), combine that recorded effect to a given track and get the same results as if the plugin was an insert on that track?
Hopefully I explained that well enough.
Old 01-16-2018, 07:17 PM
YYR123's Avatar
YYR123 YYR123 is offline
Default Re: Recording an Effect - 100% Wet
Well that’s what heat does.....but not exactly like an effect
I don’t believe this tactic will work out
Daniel
Old 01-16-2018, 08:05 PM
adam79's Avatar
Is Heat the Saturation plug for PT HD? Never tried it, as I just have regular PT. I have tried Bob's Pheonix II plugin and loved it.. not enough to drop a few hundo, but ya..
I think it's also similar to the way the Acustica Audio Aqua plugs operate.. and maybe even convulsion reverb?
Old 01-16-2018, 08:11 PM
64GTOBOY's Avatar
64GTOBOY 64GTOBOY is offline
That sounds like what audiosuite does. "Effects" plugins, along with everything else your computer does, are basically just math. An algorithm is applied to a file that is digital representation of program material. There isn't actually any signal flowing through anything in the box. You can apply an audiosuite process and have it create a new clip, but I don't think it would sound the same if you mixed it back in as just processing the file itself. The math would generate different numbers basically
Dell XPS 8900 i7-6700K CPU @ 4.00GHz 64 Gig Memory:Seagate 2x 2TB, 4TB,500gb EVO OS Windows 10 pro
PT 2023.3 Studio through an A&H Qu-32
Old 01-17-2018, 05:49 AM
Why do you want to do this? If you want to use the same settings on another track just create a custom user preset with those settings. Then you can use it wherever you want.
BTW it's convolution reverb NOT convulsion
Jack
QAPLA!
Old 01-17-2018, 12:27 PM
Sardi Sardi is offline
Oh man... I REALLY want to hear what a convulsion reverb sounds like!
Old 01-17-2018, 01:19 PM
YYR123's Avatar
I thought it was new tech !!!!!!🤩🤩🤩
Since NAMM is right around the corner!!!
Daniel
Old 01-17-2018, 01:20 PM
Convulsion reverb - that's the sound you get from the after effects of drinking too much and making use of the bathroom.
Jack
QAPLA!
Old 01-18-2018, 09:46 AM
adam79's Avatar
It sounds like me trying to create my own reverb w/o help from preaets
adam79's Avatar
Haha. Presets.
vocals sound like an effect while recording chalz2502 macOS 7 07-27-2014 07:43 PM
Delay effect happening when recording audio powerhouse0111 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 04-01-2010 01:40 PM
DELAY EFFECT WHEN RECORDING INTO DIGI 002 calibos 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 10-04-2006 11:12 AM
echo effect when recording chunkymutt 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 01-14-2005 11:08 AM
Delay effect when recording oknotok Digidesign Hardware & Software 1 05-20-2001 03:31 PM
