Go Back   Avid Pro Audio Community > Other Products > Storage Subsystems
Old 06-04-2010, 07:51 AM
:Rob: :Rob: is offline
Default Firewire flash drive
Maybe a silly question, but has anybody ever seen around a FW flash drive? I mean like a regular USB key but with a Firewire connection?
If yes, did someone tested it recording/editing/playback with PT?
I'd love to have a 64Gig drive to take around with my sessions on it.
Old 06-04-2010, 12:31 PM
mix109 mix109 is offline
Default Re: Firewire flash drive
Hi Rob
I bought 3 years ago one of These
I used as a portable/emergency boot drive,due to size limit did not try it with PT,but i can check and let you know
Kanguru,seems that they dont produce it anymore instead they switch to eSATA flash
Old 06-06-2010, 01:45 PM
Thanks for your reply. Flash FW Drives look a little bit pricey for 8GB! But the other one looks interesting. How can I use a eSata connection with a MBP without expresscard?
Old 06-06-2010, 11:58 PM
I am using THIS
with external enclosures,i assume that it will work with the flash one
Old 06-07-2010, 08:33 AM
Dism Dism is offline
Originally Posted by mix109 View Post
I am using THIS
The problem with that... is you throttle the potential benefits of using eSATA or FireWire. If you convert down to USB... you might as well use a USB flash drive.
If you want the full benefits of eSATA, you'll want a direct eSATA connection via ExpressCard.
D
a n t h e I n c r e d i b l e S o u n d M a n
"Svetlana" v1 - 4.2GHz i7, 16GB RAM, OSX 10.7.4
Liquid Saffire 56 - PT10.2 - BFD2, VCC, Duende Native, Play 3.0
_C U R R E N T-D V E R B-S C O R E:515
Old 06-07-2010, 10:21 AM
Dan,you are right about it but Rob is using a MBP _the non xpress card generation_
So probably he can use a FW HDD instead rather than a USB one.
Old 06-14-2010, 10:55 AM
That's the only qualified option, anyway...
Either way, DON'T TRACK TO USB!
D
Using a 32gb flash drive for audio drive K-Bomb Storage Subsystems 6 08-28-2012 08:56 PM
Using Flash Drive for Sessions in PT 8.0 mcr3 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 09-16-2009 11:27 AM
Anyone using Firewire Flash Drives As Opposed To A 2ndorUSB? epu 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 12-03-2007 03:34 PM
Usb Flash Drive Choices ? Anyone ? TommyT Pro Tools TDM Systems (Mac) 1 05-05-2007 02:11 PM
Firewire flash drive?? Paul Cavins 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 07-23-2004 06:08 PM
