Help: copy/paste plugin parameters (ex: 2.0 to 5.1)?
Hi folks-- not sure what else to call it so I'm just coming to the group to ask:
Here's the situation: Pro Tools TDM 7.2 (Mac) Converting, say, a 2.0 show to 5.1 So I'm having to take all the plugin automation from one to another. Didn't take me long to realize that you can't simply option-drag the plugin from the 2.0 submaster (for instance) to a new 5.1 submaster because 'the number of inputs don't match'. So basically going from any X number instance of a track (aux in this case) to a Y number instance of a track (also aux--DIA Master specifically, with 5 plugins). I normally go through the grunt work of showing the plugin's parameter automation on the track (ie: Q10 band 1 gain), copy, then go to the new track which I've set up with another Q10 and pasting into the same parameter. There's GOT to (or there SHOULD) be a way to copy all / paste all... yes? No? p.s. I should also specify--this would copy all automation changes within the track length or highlighted section, etc. Not just 'copy and paste' of a 'set' setting (ie: from here to here make all automation THIS setting)--so all gain changes, frequency changes, Q changes, etc. etc. would follow. Any help would be greatly appreciated! Not something I have to do often, so have never worried about it; but another case came up taking a 2.0 mix to a 5.1 mix and here I am again. Thanks. |
Re: Help: copy/paste plugin parameters (ex: 2.0 to 5.1)?
Hope this helps, Timothy |
Copy Special has 'all automation', 'plugin automation' (and 'pan automation' but n/a in this case).
But I can't Paste Special (only option available is 'Repeat to Fill Selection', 'Merge' and 'to current automation type' are greyed out at this point). And a simple 'paste' results in 'some automation parameters in the clipboard do not match the paste destination'. Thanks, though. |
Copy/Paste plugin automation | Rune Thuelund | Post - Surround - Video | 18 | 03-28-2012 01:35 PM |
Copy/Paste Special Plugin Autom: greyed out? | SD2 | macOS | 2 | 10-19-2011 01:34 PM |
copy plugin data ,paste on another parameter ? | andre tchmil | Tips & Tricks | 2 | 01-17-2007 10:36 PM |
Copy/Paste Automation of Multiple parameters | noizgirl | Pro Tools TDM Systems (Mac) | 1 | 01-24-2005 10:54 PM |
Copy/Paste Automation of Multiple parameters | noizgirl | Tips & Tricks | 0 | 01-21-2005 03:46 PM |
