Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools M-Powered (Mac)
Old 09-14-2010, 02:21 PM
sitarartist sitarartist is offline
Default Analog inputs 5-8 not seen as inputs on tracks
I use M-Powered ver 8.0.3 with Profire 2626, Intel-Mac OSX 10.6.4, 2.16 Ghz Intel core 2duo, 3 gb RAM.
While creating a track, when I click on input, I see only analog inputs 1-4 only and not 5-8 (in both Mix window as well as edit window). In the Profire control panel, analog inputs 1-8 are checked as active. In I/O setting in Protools, analog inputs 1-8 are shown.
What am I doing wrong, can someone please help...thx.
Old 09-14-2010, 03:38 PM
barters81 barters81 is offline
Default Re: Analog inputs 5-8 not seen as inputs on tracks
What sample rate is the session you've opened?
I too have a 2626, and sometimes my inputs go missing and I need to setup the input outputs in PT. So double check them.
I ask the question about the sample rate as higher sample rates will reduce the number of active inputs.
- Macbook Pro 2.5Ghz, 4gb RAM, 320Gb HD @ 7200RPM
- 2 x Profire 2626
- PT8.0.1 M-powered
- Yamaha HS80M
- Axiom Pro 49
- 500GB Sarotech Hardbox external HDD plugged through express card, FW800
- Waves Gold bundle, L3-16, Eddie Kramer
- 2 x Coles 4038, Royer 121, 2 x Shinybox MXL, 4 x SM57, 3 x SM58, AKG D112, SM81, Shure 16A, sE 2000, 3 x Audix D2
Old 09-15-2010, 06:46 AM
Sample rate is 44.1 and 24 bit. I went into I/O set up and ensured that the inputs are default...still it is not showing up. Just to save memory, from the Profire control panel, I disabled the ADAT paths....I reinstalled the Profire drivers...no change...
Old 09-15-2010, 08:08 AM
bradch00 bradch00 is offline
Have you tried deleting the entries from the I/O definitions in PT and creating them again?
Also if you are using them in a mono track instead of a stereo one, make sure that 2 mono sub-inputs are defined as well as the stereo one by expand it.
Pro Tools, Studio One Pro
2022 Mac Studio M1 Max 64GB-1TB NVME
OWC Thunderbay Mini (4TB SSD)
OWC Express 4M2 (4 X 2TB)
Interface: Presonus Quantum
Presonus Faderport & Faderport 8
Black Lion Sparrow Mk2 A/D, FMR-RNP-RNC, MIDI Xpress 128
BM5A, KRK VXT4, Equator D5
2020 Macbook Pro 16GB RAM, 512GB SSD Audio(mobile rig)
Old 09-16-2010, 08:24 AM
Thanks a lot bradch00, not defining the 2 mono sub-inputs was the issue. I am a novice, as you can tell, and didn't realize this. Thanks once again for your time and help.
24 analog inputs on an HD I/O? nerdlinger Pro Tools HDX & HD Native Systems (Mac) 14 09-11-2012 06:25 PM
How many analog inputs? Jeffrey Talbot Pro Tools M-Powered (Mac) 7 08-13-2008 03:59 PM
8 More Analog inputs in 96 i/o? Robby Hamilton Pro Tools TDM Systems (Mac) 1 08-25-2002 10:45 AM
8 analog inputs on 001?? jacko32 General Discussion 7 08-20-2002 01:51 PM
?Need more analog inputs? Jahmontee 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 03-02-2000 10:58 PM
