Old 03-26-2011, 11:43 PM
steveejay_1 steveejay_1 is offline
Default 2 digi002 racks - optical clicks
Hi.
Running Pro Tools 9. I have 2 digi002 units linked via optical cable. When I select a channel from the slave unit I get clicks, some loud but shows on the channel meter on pro tools. When I run both units individually there are no clicks. Is there a setting in pro tools that needs to be set? Tried lowering the buffer rate to 128 with no luck. Can you link both digi002's individually via firewire to the computer? I have tried this but pro tools doesn't recognise the second 002. Any help would be appreciated.
Thanks.
Steve.
Old 03-26-2011, 11:49 PM
Dism Dism is offline
Default Re: 2 digi002 racks - optical clicks
Originally Posted by steveejay_1 View Post
Hi.
Thanks.
Steve.
You definitely can't use both at the same time through firewire, but one in standalone mode should be ok.
Make sure you select optical clock source in Setup > Hardware.
D
a n t h e I n c r e d i b l e S o u n d M a n
"Svetlana" v1 - 4.2GHz i7, 16GB RAM, OSX 10.7.4
Liquid Saffire 56 - PT10.2 - BFD2, VCC, Duende Native, Play 3.0
_C U R R E N T-D V E R B-S C O R E:515
Old 03-27-2011, 02:01 AM
Thanks for that. No more clicks. In saying that when the system sits in idle for a while a static sound comes over all inputs and I need to reboot the whole system to get rid of it. Any ideas?
Old 03-27-2011, 02:41 AM
Is the screen saver coming on? Could your computer be trying to idle your hard disks? Does it go to sleep?
D
Old 03-27-2011, 02:51 AM
Thought it might have been the screen saver. Waited for it to kick in and didn't happen. Not at the system now so I'll have a look tomorrow and let you know how I go.
Thanks for the quick reply.
Regards,
Steve.
[IMG] code is Off
Digi001 optical - pops & clicks Bob Smith 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 02-10-2012 08:01 AM
Linking 2 Digi002 Racks matthaumschild 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 07-16-2009 12:12 PM
Linking 2 DIGI002 racks Red Tape Studios 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 07-12-2007 07:01 AM
T-Racks with the DIGI002 Jose A Lugo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 03-11-2005 09:28 AM
Pops and clicks from optical out of Adat jwstudios2000 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 11-05-2000 02:31 AM
