Can't open PT 5.1 file in PT 7.4
I'm using PT7.4 on a MAC g5 dual 2.0ghz. Recently I've had a call to open some old files which were in 5.1.
When I try to open them PT crashes and I have to restart. A few files have worked ok but of course, not the ones I really need. Any ideas? Thanks |
Re: Can't open PT 5.1 file in PT 7.4
One thing to look at are the characters in the file name.... in the OS9 days, all of my sessions started with dates: 09/03/98
OSX doesn't like the "/" in the file name, and crashed PT every time. Your other option is to create a new session and see if you can import the tracks into it. |
I'd also suggest you try shift-double clicking to open the session which will open it with all plugins inactive. This should at least identify if a specific plug is causing the problem.
Also what format are your audio files? And have the sessions ever been on a PC or a FAT32 formatted hard drive? Have you tried an import session data instead? Does this also crash? |
Thanks...importing the session data worked!
Can Open HD file on PT 10?? | bcrichguitar | macOS | 1 | 01-05-2012 04:19 AM |
File not open (-38) | omnipop | Pro Tools TDM Systems (Mac) | 2 | 04-24-2009 07:06 PM |
File not Open (-38) | Bigpit | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 04-23-2008 11:30 PM |
Open up a .pt5 file! | MikeGSPR | Pro Tools M-Powered (Win) | 3 | 03-13-2008 06:53 PM |
Can't Open/Create new file from File Menu | nob turner | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 12-07-2003 11:04 PM |
