Old 03-08-2020, 06:02 PM
GreenWire GreenWire is offline
Default Errors in Projects: "Failed: Bundle Error"
Hey folks. I finally decided to give the cloud collaboration a try, and have run into a problem right off the top. I've created a project, and in the Task Manager I see that it's tried to post Tempo, Markers, new tracks, etc., but all of those have failed, and I see the uploaded project attempt says "Failed: Bundle Error". Any suggestions?
Thanks.
Old 03-08-2020, 07:18 PM
JFreak's Avatar
JFreak JFreak is offline
Default Re: Errors in Projects: "Failed: Bundle Error"
Hi, how about some more information regarding your setup..?
Janne
Old 03-08-2020, 07:31 PM
Sure, I guess that'd be helpful. I've tried it on two computers, a 2018 MacBook Pro and a 2019 MacPro, both running 10.15.3. I'm in Pro Tools Ultimate 2019.12.0. On the MacBook I'm just using the internal drive, on the MacPro I have the session created on an external SSD.
Old 03-08-2020, 07:32 PM
JFreak's Avatar
I also have trouble with projects on Catalina. Better wait for 2020 version and meanwhile revert back to old config
Janne
Old 03-08-2020, 07:34 PM
Ahh well, too bad that doesn't work yet. Hopefully in the next update.
Old 03-08-2020, 07:47 PM
I actually did a little Googling at projects and Catalina, and found that it does work, but you have to enable Full Disk Access for Hub and TransportClient. TransportClient wasn't already in the Full Disk Access list, but it was easy enough to find in Spotlight. Here's the link to the Release Info:
http://avid.force.com/pkb/articles/D...2-Release-Info
Old 03-09-2020, 03:01 PM
JFreak's Avatar
Ahh.. thank you!
Janne
"AAF Library Initialization Failed" Error mmartin046 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 01-28-2016 03:06 AM
"Failed Installation" errors with Application Manager 2.3.3 General Stalin Pro Tools 12 5 05-17-2015 04:21 PM
What does this mean? "AAF Files Library Initialization Failed" error Terry Wetzel Windows 6 03-06-2015 05:43 AM
"Quick Start has failed" error when launching Pro Tools SE AvidCS Pro Tools SE and Essential (Mac) 1 03-10-2012 01:51 PM
PT refuses to close projects; error; "FindAsset failed" berbokip 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 08-10-2009 01:32 PM
