Can't work in 88.2 anymore on PT9?
so i just tried to boot up a session in 88.2 but i wasn't given the option... i saw 44.1, 48 and 96 but not 88.2? i'm confused as to how it just dissapeared from the default options? not sure where to look in PT/Preferences, etc to approach this?
also how do I default my playback engine to my 002 rack? it always opens default with PT aggregate. then when i switch to 002 it goes through this tedious process i have to wait for the session to close/reload with the new settings. |
Re: Can't work in 88.2 anymore on PT9?
BUMP!
I have absolutely no idea why i can't see 88.2 in my sample rate options!!! someone please help me! |
88.2 is not a samplerate commonly available with onboard audio, so it won't be seen while using aggregate I/O.
However, when using the 002 it should show up. In Playback Engine do you have the 002 selected as your playback device? When it is, 88.2 should be available as an option.
D a n t h e I n c r e d i b l e S o u n d M a n "Svetlana" v1 - 4.2GHz i7, 16GB RAM, OSX 10.7.4 Liquid Saffire 56 - PT10.2 - BFD2, VCC, Duende Native, Play 3.0 _C U R R E N T-D V E R B-S C O R E:515 |
Personally, Pro Tools defaults to whatever hardware I was using last... but if say you were to boot your computer with the 002 turned off, it will probably default to the next available hardware. You can, however, hold "N" while Pro Tools starts up and then select the 002 as your playback device before opening any sessions.
rec + play does not work anymore | deardaddy | ICON & C|24 | 6 | 06-17-2012 02:25 PM |
Plug-ins won't work anymore | Mattitude | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 07-20-2009 12:23 PM |
Pro tools won´t work anymore | Noctune | Pro Tools M-Powered (Mac) | 1 | 05-01-2009 03:21 PM |
Midi doesn't work anymore | kd_rome | MIDI | 1 | 06-24-2004 10:16 AM |
PT 5.01 + OMS + Logic 4.5 don't work anymore! | smcoptyltd | Pro Tools TDM Systems (Mac) | 4 | 10-17-2000 10:13 AM |
