Go Back   Avid Pro Audio Community > Legacy Products > ProControl, Control|24, Command|8
Old 06-23-2006, 12:01 PM
7k 7k is offline
Default Grid Button resets to \"Relative Grid\"
Hi all,
I seem to have a new issue. I commonly bounce between Slip and Grid modes. For the longest time, if my Grid was set to Absolute Grid, when I would hit "Slip", then return to "Grid" with the grid button, it would always stay in Absolute. But a month ago, that seems to have changed. Whenever I return to Grid, it defaults to "Relative Grid", then I have to hit Grid again to get to absolute. If I use the mouse, or Keystroke (F4), it does NOT do this. It ONLY does this on the PC main unit mode buttons. Is this something that happened with a new firmware update or something? Is there some place where this can be turned off? I never use Relative grid mode, and this keeps confusing me when things won't slide on the grid!
Thanks for any help!
Paul
Paul Dexter
7k' Productions
7kproductions.com
Old 07-03-2006, 06:03 PM
Produce_Dept Produce_Dept is offline
Default Re: Grid Button resets to \"Relative Grid\"
Same thing on my system. I usually use the keyboard to switch so I hadn't noticed this before....
Kurt Bullock
PT 7.4 HD2Accel Digi ProControl
G5 Dual 2.7 3.5gig RAM OS10.4.8
www.zeropointrecording.com
Old 07-22-2006, 11:07 AM
7k 7k is offline
Thanks,
It must have been added in the last firmware, because it never seemed to do it before.
paul
Paul Dexter
7k' Productions
7kproductions.com
Old 07-22-2006, 07:13 PM
RobMacki RobMacki is offline
Same here
It toggles back and forth each time you go from slip to grid
Old 01-26-2008, 06:47 PM
Ru_C Ru_C is offline
Same here
Yes, it's irritating..be great if it was fixed
xx
A Rig: (Studio) I7-7700k Hackintosh - OSX 10.15.7, PT Ultimate2023.6 Native PCI-e Card, AVID I/O16 Analog i/o x2, 40 fader D-Command ES
B Rig: (Home/Office). M1 Mac Studio - 64gb ram - OSX 12.7.1, PT Ultimate2023.6, HD Native Thunderbolt, Omni, Avid Artist Control
http://www.lostboysstudio.com
Grid Mode...Absolute or Relative...the difference? Roy Howell 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 10-12-2012 02:54 PM
Slip to Grid mode no visual grid unless pressing "grid" mgoorevich Pro Tools 9 5 11-13-2010 07:11 AM
Separating MIDI Notes in Relative Grid Mode filosofem MIDI 0 03-13-2009 03:22 PM
Feature request: relative grid lock mr.armadillo Post - Surround - Video 0 01-24-2007 02:11 PM
Relative grid weirdness snoopy Pro Tools TDM Systems (Mac) 1 12-28-2004 01:04 AM
