Two signal path questions
1.
I feel like I should have determined this long ago, but what is the signal path on the insert section of a track? Does it go top to bottom or bottom to top? 2. Does PT ever limit the number of bus paths? I recently discovered the feature of renaming a bus path, which, in most of the sessions I've been working on recently, also creates an entirely new path while leaving the original path free, i.e., if I rename "11-12" to "Gtr Verb," then I get a new bus path without losing "11-12." But in one session, that's not the case; I seem to have run out of paths. A few of the bus paths still have their default numbers and the rest have custom names. The total number of bus paths I have access to there is 22, or 11 stereo pairs. I'm using the 2018.4 version.
Nobody told me there'd be days like these .. .. .. strange days indeed .. .. .. |
Re: Two signal path questions
1. Top to bottom. Limited to 10.
2. Afaik no, as soon as you default the i/o the list will repopulate the busses no renamed starting on 1-2 again.
Dell XPS 8700. Intel Core i7-4770 CPU @ 3.40GHz. RAM: 16GB. Windows 10 Home x64. NVIDIA GeForce GTX 645. NI Komplete Audio 6. Pro Tools Software 2019 amagrasmusic.com |
Thank you!
firewire signal path | nplmdthfan | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 07-15-2010 03:10 PM |
Signal Path (for an 001) | Cavet Your Eruptor | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 07-28-2006 12:55 PM |
Signal Path | bluesna | Tips & Tricks | 0 | 01-10-2005 01:02 AM |
Signal path for turntable | Ignatius Reilly | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 03-28-2004 07:40 AM |
C 24 signal path (does this look right?) | sidereal | ProControl, Control|24, Command|8 | 3 | 03-19-2001 01:12 AM |
