Digimax Digital Mayhem
I've done a cursory search, but haven't seen this exact problem.
Digimax in to a 002. Both units and Pro Tools session are set to 48k. Additionally, a focusrite stereo pre is being used via inputs 7&8. The armed tracks from the Digimax are immediately causing horrendous digital clipping. This is with the gain at 0. The Focusrite tracks ar functioning perfectly. By deductive reasoning; PTLE- working fine 002- working fine Focusrite-working fine Digimax- not so much. I assume this is a lightpipe problem, but I don't know how to fix it. Any thoughts would be greatly appreciatted. Thanks, Jace
Mac Pro 2.4 Quad, 8 Gig RAM Snow Leopard 10.6 HD Native PT 10 Omni Waves Platinum NI Komplete 8 API 512c, LA 610 Some Mics, Some guitars Some Songs |
Re: Digimax Digital Mayhem
try a new light pipe cable
www.soundgeekproductions.com |
Really?
I thought with light pipe it either worked or didn't work at all. What the hell... I'll give it a shot. Thanks! Anyone else?
I had a similar problem and just re choosing the optical choice in the hardware setup fixed it.Its worth a shot.
Ray |
Try using the digimax at another sampling rate. make sure you are using the clock of the digimax. if not it might be the crystal converters in the digimax, happened to me.
http://www.thegaragestudios.org |
Bouncing mayhem | carterobrien | Pro Tools M-Powered (Mac) | 4 | 02-26-2009 06:56 PM |
Presonus Digimax and 192 digital IO | yotam agam | Pro Tools TDM Systems (Mac) | 4 | 03-03-2005 01:17 PM |
Digimax vs. digital mixer? | Sickstring420 | Tips & Tricks | 3 | 11-22-2004 05:16 PM |
Authorization Mayhem | Loose Nutt | Pro Tools TDM Systems (Mac) | 1 | 11-09-2003 12:01 PM |
original G4 mayhem | imixrico | Pro Tools TDM Systems (Mac) | 0 | 02-09-2000 08:51 AM |
