MBOX SONAR SOUNDFORGE ???
I purchased MBOX bundle and I am beginning to regret this. I cannot use Soundforge with any sound playback or record into soundforge. Soundforge is one of the best recording software out there. How can DIGIDESIGN not support this?????
I am using Pro Tools LE update to 6.4 and using Digidesign sound driver update and WIN Service PACK 1a Any suggestions before I return this? |
Re: MBOX SONAR SOUNDFORGE ???
Unfortunately you can only 'playback' Soundforge thru the Mbox.You would need to install the Wavedriver and the MME helper from this web page
The work around to record, is to record into Protools and then export the regions as files and open them in Soundforge.It works for me. Sonar is both I/O using the ASIO driver that would have been installed with your 6.4 It is not Digidesigns fault, it is Sony/Sonic Foundry's, they need to add ASIO support for Soundforge, as they have with Acid and Vegas.
Bazzle |
Thanks Bazzle. I installed the MME driver and this worked.
Btw, do you know the best way to edit in Soundforge from Pro Tools LE. Looks like it used to be much easier in with Sonar. |
Bazzle |
2 questions- mbox/soundforge and preset management | mrufino1 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 09-26-2005 10:42 AM |
Sonar and mbox? | opt1k1 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 09-03-2005 11:08 PM |
Soundforge w/001 worked..w/Mbox not working help! | bryanbassett | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 10 | 11-12-2003 09:24 PM |
Mbox & e.g. Soundforge | kekkonenurho | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 02-25-2003 01:21 PM |
getting soundforge to output to mbox (asio drivers?) | dj:A | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 01-24-2003 10:16 AM |
