Go Back   Avid Pro Audio Community > Other Products > Pro Tools Express on Windows
Old 09-08-2014, 12:20 PM
timcrow420 timcrow420 is offline
Default Is there a way to get a 4 count before recording starts?
Ive been tinkering around with the pre roll, and post roll in the transport section, and I tried tampering with the click/countoff, in the setup window, but I cant for the life of me get any count before recording begins, can anyone help me out?
Old 09-11-2014, 04:10 PM
Benoni's Avatar
Benoni Benoni is offline
Default Re: Is there a way to get a 4 count before recording starts?
Did you select "Count Off"? Make sure it's hi-lighted green.
If you do not see the option, click the little down arrow and make sure you are showing MIDI Controls on the transport.
You can double click the Metronome Button to open the Click/Count Off Options.
You can also use the number '8' on the Numeric Keypad to toggle Count Off ON/OFF if it is set to Transport.
This info if for regular Pro Tools, I'm assuming it's the same for Express. I'll check and if it's different I will let you know.
Attachment 2663
Brian
Windows 11 Pro | macOS 12
Pro Tools 2022
benonistudio.com
Youtube Channel - benonistudio
Plugin Deals
@benonistudio
Old 10-27-2014, 11:07 AM
Thank you for your help, I found it, and you were exactly right, just like on pro tools 11, it was outlined in green, but not highlighted in green.
Delay until recording starts... T. C. Gass Pro Tools M-Powered (Mac) 2 01-10-2006 07:27 AM
Long Delay before recording starts. Hekler 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 06-19-2004 02:17 AM
? Pause before Recording starts in PT's Mix plus / 5.01 vze24x2x General Discussion 2 04-24-2001 06:45 PM
Latency before recording starts LEV 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 09-11-2000 11:20 AM
HFS+ slow recording starts wallygrant Storage Subsystems 3 09-04-2000 06:11 AM
