Old 06-07-2002, 12:05 AM
xbernix xbernix is offline
Default PTLE VIOLATION ERROR CAN NOT EXIT
hi pt userers maybe someone has a tip for me I dont realy know what changed in my system (p3 asus mobo)the sessions can not be closed using the windows icon or the exit in the ptle soft the only way ctr+alt+del so the soft closes .when I try to open again I receive a violation error I
have the feeling that some drive has been deleted when I taked out some demo soft ,plse if some body has a clue about I need help
thanks to all
many thanks to QUICKDRAW about the information about the floppy searching before stating sessions
bernardo
Old 06-07-2002, 11:49 AM
DigiTechSupt's Avatar
Default Re: PTLE VIOLATION ERROR CAN NOT EXIT
Perhaps some other software running in the background is conflicting. Disable all Startup Items, reboot the computer and see how things go.
1) Start Menu > Run > Type in: msconfig > OK > System Configuration Utility Menu appears > Startup Tab.
2) Disable startup items that do NOT have C:Windows in explanation.
3) Do NOT disable: Scan Registry, System Tray, and Load Power Profile (both).
4) Disable all other items that might appear.
Brent
Avid Audio Tech Support
Support FAQ
Old 06-07-2002, 12:18 PM
Swaphappy Swaphappy is offline
My PTLE gives an access violation when I leave a ZIP disk in the drive.
Not complaining, just stating a fact.
I think the same thing can happen if the drive letters are reconfigured by adding another HD or CDROM
Access Violation error on exit Legion6789 Pro Tools 10 7 12-22-2011 09:07 PM
PTLE 8.0.4 ALWAYS crashes on exit jnystrom 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 09-13-2010 09:54 AM
Help with "Could not complete the exit command because Access Violation occurrred" keithl 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 03-06-2010 07:24 PM
PTLE - Where's the EXIT? tho3hite 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 43 12-04-2009 03:03 AM
PTLE 5.3.1 Xp crashes on exit! cwild 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 10-01-2002 01:25 AM
