Old 06-02-2007, 11:12 PM
akakpaws akakpaws is offline
Default Record vs Transfer Drives
I have an AMD 4.1 Ghz, 1G ram. The installed HD is 250 G 7200 rpm, and I added a 500G 7200 rpm SATA HD. I don't understand this concept of record vs transfer HD. Can anyone help? This seems to be an important concept to understand in PTLE 7. Which HD can/should be assigned as record/ Transfer?
Thanks!
Old 06-03-2007, 01:24 AM
Default Re: Record vs Transfer Drives
A Transfer drive may be a drive which doesn't have the technical specs for multitrack playback and record or just a drive which you use for backups. A Playback drive could be set for Round Robin recording when you wish to make sure the drive isn't included in the Round Robin. A Record drive is obvious.
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
Old 06-03-2007, 10:07 PM
Here is another tidbit that might help. If you format a new drive as a Dynamic drive, you cannot record to it. Any audio drive that you wish to record to and playback from, must be formatted as Basic. To check, right-click on My Computer>select Manage>select Disk Management. On the left column where the drive letter is displayed, you should see either BASIC or DYNAMIC. If you see Dynamic, reformat as Basic(delete the partition first).
Old 06-06-2007, 08:23 AM
Thanks very much, this is very helpful. I assume if I decide to reformat a drive from dynamic to basic it erases all the date on the drive?
Old 06-06-2007, 08:26 AM
Thanks very much for your response. I am not sure what is meant by 'round robin" recording. Does this refer to record/playback?
Old 06-07-2007, 08:11 AM
Yes it will erase everything so back it up if it matters. I keep a few USB drives just for that purpose(I never record to a USB drive).
Old 06-11-2007, 09:16 AM
Thanks very much for your help. Regarding formatting, I don't recall seeing an option to format my second 500 mb SATA hard drive as basic or dynamic. Is there anything else you can add which might help me figure out how to find out which format I have or how to ensure when I reformat I will be formatting as basic? Thanks again very much.
Old 06-11-2007, 09:18 AM
I just re-read your post and realized that you did also mention how to check for the existing format type, thanks a lot. So alls I need more info. on is how to go about formatting the drive as "basic". Thanks again.
Old 06-11-2007, 09:20 AM
Got it, thanks very much!
Old 06-11-2007, 09:39 AM
EGS's Avatar
EGS EGS is offline
..how to go about formatting the drive as "basic"...
Google found this answer.
Desktop: PT 2019.10 / Win 10 / GIGABYTE GA-X58A-UD3R / i7-980X hex @ 3.9GHz / 32GB / Focusrite LS56
Laptop: PT 10 / Win 7 / HP ProBook / i7 quad / 8GB / U-PHORIA UMC1820
Legacy rig (works): PT 5&6 / MAC G4 OS9&OSX / DIGI001
Info/Services link
LE 8.0: All Drives Magically Set to Transfer Only SeventySix 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 09-23-2009 10:35 AM
drives mysteriously switched from Record to Transfer Reitzas Pro Tools TDM Systems (Mac) 6 03-30-2008 01:21 PM
All drives are Transfer only! Tim Cole 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 12-07-2007 08:45 AM
usb thumb drives for transfer halfguard 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 02-03-2007 01:48 AM
Best way to transfer system drives OR Studios General Discussion 0 03-14-2001 12:37 AM
