How to Join & Post  ē  Community Terms of Use  ē  Help Us Help You
Knowledge Base Search  ē  Community Search  ē  Learn & Support
Old 11-12-2019, 02:12 AM
monnecka monnecka is offline
Default PT 2019 suddenly running out of memory?
I have a 2013 Mac Pro W 64gb of memory.
The last mix I have tried to do I keep running out of memory.
No idea what this could be... Iíve had sessions with a ton of plugins and tracks etc before and no problem.
This one I deactivated and hid all tracks except 16 of them. I was using ez drummer and I committed the midi to audio etc.
Most of the plugins I use are UA plugins so I donít see how they can be the problem.
Some things that have been odd to me are as follows:
I know in PT 2018-2019 they changed something where you could add plugins or move them etc and you wouldnít be interrupted etc.. that worked when I first installed but now itís the same as it used to be ... everything stutters etc...
I think I read somewhere that you needed to have something set a certain way for that to actually work.. maybe I switched that off somehow?
Please excuse my ignorance here as I am new to the forum and havenít had much posting experience.
Also if I run out of memory I can usually get away with continuing maybe until it happens once or twice but then I get this digital noise sound when I hit play and it sounds all messed up and I have to literally restart my computer to fix that issue and continue.
Anyone have any clue what could be wrong?
I have maxed out the memory.. Iím using the highest buffet 1024 I thing it is? I forget Iím not at the console right now..
itís never done this and all of a sudden now itís non stop.
Thanks in advance :)
Spanner on S6 running 2019.5.1 quadraphonics Avid S6 17 11-11-2019 12:53 PM
PT 2019.6 not clearing memory fsavell Pro Tools 2019 1 10-14-2019 09:31 PM
HELP! Pro Tools suddenly running at snails pace gostudionc Pro Tools 2018 6 06-21-2018 06:07 PM
PT HD9 (running native with motu) running out of memory syMPh Pro Tools TDM Systems (Mac) 1 11-21-2010 08:34 PM
session suddenly running extremely slow jonahjonahjonah 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 02-16-2006 08:32 PM
