Old 07-15-2005, 02:37 AM
deepfrequencies deepfrequencies is offline
Default How to store presets in \"Plug-In Settings folder\"?
Hi, I'd like to save some plug-in settings that I created, but I can't figure out where, except in the Root Settings folder which is inside the Application Support -> Digidesign folder which would not be very helpful when taking my hardrive somewhere else. A pop-up message says I can store them in a Plug-In Settings folder inside the working session's folder, which would be perfect, but I can't find such a folder. How do I create Plug-In Settings folder inside a working session? Thanks.
PT 6.4, OS 10.3.4, Powerbook, MBox
Old 07-15-2005, 06:18 AM
ricupad ricupad is offline
Default Re: How to store presets in \"Plug-In Settings folder\"?
In the plug-in window, click the arrows next to the preset name, go to 'setting preferences>save plug-in settings to' and select 'session folder'. This will create a plug-in settings folder within your session folder and your settings will be saved there.
R.
Old 07-15-2005, 10:36 AM
Eureeka, it works! Thank you very much for your help, ricupad.
Old 07-15-2005, 11:48 AM
You're wellcome.
R.
Plug-in settings/ presets names gone amp_88 macOS 0 04-01-2013 02:08 PM
Why can't I set my plugins root settings folder outside PT's default folder? RiF Pro Tools 9 4 09-26-2011 12:11 PM
Bloated Plug-in Settings Folder morganpage 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 02-17-2009 10:57 AM
Plug-In Settings root folder problem TJS Pro Tools TDM Systems (Win) 1 06-12-2008 04:03 AM
Cannot save plug-in settings to Root Settings folder SimonORorke Pro Tools M-Powered (Win) 1 01-18-2008 08:38 PM
