Old 03-22-2000, 07:06 PM
Jason Jason is offline
Default Re: headphone monitoring set-ups
DOD makes a cheap stereo in and 6 stereo out headphone amp. Street price $150 or so I think. Set up aux sends out two analog outputs into headphone amp input.
Old 03-22-2000, 10:53 PM
Preston Klik Preston Klik is offline
Rolls (I think) makes one too.
I saw it @ Guitar Center.
Seemed like a cool idea.
Old 03-22-2000, 11:07 PM
Gremz Gremz is offline
I have the Rolls unit. It works fine. It has 6 inputs and you can send either mono or stereo signal. Also has outputs on it.
I send a stereo aux mix to outputs 7 & 8 on the 001 over to the headphone distro and it works great!
Gremz
Old 03-23-2000, 12:50 AM
vince v vince v is offline
Default headphone monitoring set-ups
what do you guys recommend for running multiple headphones off of the digi? i've looked around a bit and haven't found much in the way of running a bunch of headphones for monitoring during recording. is there a "splitter" box i can get that plugs into the headphone jack on the digi that has multiple headphone ins for everyone to plug into. is this a simple device that radio shack carries or does it involve something more complex? thanks again, vince v
Old 03-23-2000, 04:52 AM
phobia phobia is offline
"Behringer" as a new one, and also
"StageLine PPA-1" and also
"Music and More HP48"
// Joakim W
>>We need more time so that everything doesn't happen at once<<
Digi 002
Mbox 1
Digi001 (retired to shelf)
Asus P5K Premium v3, Q6600, 2x2GB Corsair
Tyan Thunder n3600B (S2927A2NRF)
2xAMD OPTERON 2214 2.2GHZ
Win XP Pro SP3
Old 03-23-2000, 09:08 PM
Sir Bob Sir Bob is offline
I would like to monitor my vocal recording with some reverb to help me sing but I don't want to print the reverb. Any suggestions? Would one of these headphone preamps do the trick. I don't have a mixer. I just want to just the Digi and a headphone mixer if necessary.
Old 03-23-2000, 10:51 PM
There are several way of accomplishing that, even without the use of an external headphone amplifier (unless you are several persons needing listening at the same time).
Regarding Reverb. No Reverb is ever printed to the audio file unless you route a reverberated signal as an input for an audio track.
If you use a send,group fader or an insert using reverb (for monitor listening), and record on the audio track, the signal will be recorded dry.
However, you might want to set it up so you can control the listening level of the channel being recorded independently of the recording level of the same.
To do that you can either use the send knobs (for traditional headphone mixing) or just make suer you have an AUX Input track online for listening purposes. Tweak that channel so the listener is happy (using sends/returns or inserts).
Then you can apply the same input in the break-out box on an audio track for recording purposes (you might want to mute that track for listeners while recording).
You could also just listen on the audio track directly (loosing some benefits as decribed above), or if you want effects to be printed, you could set the output of your AUX IN fader to a bus and the input of an audio track to the same bus.
Try doing some experimenting on this. The mixer is very configurable and can be applied in many ways.
//Joakim W
Digi 002
Mbox 1
Win XP Pro SP3
003 Headphone Monitoring meanie2188 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 11-11-2010 12:03 PM
Headphone monitoring MikeSoloway 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 07-18-2003 11:11 AM
Headphone Monitoring Christoph1123 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 07-13-2001 09:06 AM
Headphone monitoring with effects ... phobia 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 02-22-2000 08:32 PM
Headphone Monitoring Greg Malcangi ProControl, Control|24, Command|8 0 12-09-1999 11:54 AM
