Go Back   Avid Pro Audio Community > Pro Tools Hardware > FireWire & USB Audio Interfaces (Win)
Old 06-08-2013, 10:15 PM
KD11520 KD11520 is offline
Default Re: Have PTLE 7.1, Bought a used MB2Pro and 7.1.2 update won't install
Thanks for the "Pros" (no pun intended) to install the later version.
So I did get the disks (7.3 and 7.3.1 updater) with the used MBox2 Pro. Obviously they include all that is required to run the "Pro".
So, since I've never bought a used version of PTLE before and always had my own, what will it take to get this running?
The DIGI authorization code came with the Disks. The iLok didn't.
Do I need to uninstall PTLE 7.1? If I install 7.3.1, will my old MBox2 still work? What happens to the Plug-Ins and Virtual Instruments that are in 7.1? Do I have to contact AVID to get the authorization code in my name? Do I need to buy a new iLok (shame because I'll be moving to 10/11 soon!)
Digidesign really left a lot of snare wire traps for its base. What a shame. AVID probably doesn't want to go back and fill the gaps either.
I understand the bitterness out there.
Thanks for any clarifications you can provide folks!
Old 06-08-2013, 10:37 PM
Bruce Paine Bruce Paine is offline
Admin Emeritus
Not a problem, you don't need an iLok for Pro Tools LE authorization, just that authorization code that you have.
iLok authorization for non-HD or M-Powered versions of Pro Tools started with Pro Tools 9. Authorization codes were used until the last version of Pro Tools LE (v8.0).
You should. On Windows, you may get a prompt during Pro Tools 7.3.1 installation to uninstall the previous version anyway.
Yes.
You should have updated versions of all of those on your 7.3.x installer disks.
Not necessary.
You won't need an iLok until you get v10/11, which will require the latest iLok v2. So if you do buy an iLok, don't get the older iLok shaped like a key.
Bruce Paine
System Details
Old 06-09-2013, 09:34 PM
Hi Bruce,
What a pleasant surprise. All your responses were better than I was expecting! Thank you!
So, no iLok won't affect anything? I was under the impression, third party plug-ins and virtual instruments won't work without it. If this isn't an issue, this is the best $80 I've spent in a long time.
I am looking forward to reviving my turntable and converting vinyl to digital and posting some of the better stuff on YouTube. (and record on 4 channels simultaneously) (drums)
Thank you again for the guidance and staying on top of this.
Regards//Keith
bought heat how to install [solved] Filmusic Pro Tools TDM Systems (Win) 7 02-09-2013 07:43 AM
CAN ANYONE HELP? :( I bought M Powered 8 and can't even install off the disk! bezley Pro Tools M-Powered (Win) 7 07-31-2010 11:59 PM
PT8 update for LE users that just bought TCLguy1 Pro Tools TDM Systems (Mac) 2 12-20-2008 10:35 AM
Just bought dvtoolkit2 license, how to install? krishkrasj 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 10-27-2007 02:45 AM
Just bought HD2 Anyone Got Any Install Tips? wolfman_rob Pro Tools TDM Systems (Mac) 1 10-30-2006 10:37 PM
