Old 06-26-2019, 03:24 PM
thumos thumos is offline
Default S3 OLED Issue
After installing the last two versions of ProTools, ProTools Control, and EuControl, I get these blocks appearing in the bottom windows of the S3 (see pic). Anyone else getting these? What's happening?
Old 06-26-2019, 10:04 PM
gwhatley's Avatar
gwhatley gwhatley is offline
Default Re: S3 OLED Issue
If you mean the upper right, aren't those the track numbers? See if that's checked in Eucon preferences, & deselect it.
Sent from my LG-H872 using Tapatalk
Garrard Whatley
Seismic Post Audio
Post Audio for Film and Television
System/Hardware Info
IMDb credits
Old 06-26-2019, 10:51 PM
BScout BScout is offline
Can't tell if you mean the "flip fader" signifier where that control has been sent to the faders instead of the knob.
Old 06-26-2019, 11:29 PM
mattrixx mattrixx is offline
Hi thumos, that would probably be the new behaviour settings in Eucon under General > "Attention Most RecentlyClicked DAW Area"
If for example, if you have all of those options selected (which is the default after the update), the Bottom row OLEDs will go into channel mode for the selected channel.
Select a plugin with the mouse on a channel in ProTools, and the S3 will go into "Channel View", like hitting "Shift + Channel" on the S3 and the selected plugins parameters will be spread across the bottom row.
Matt McKenzie-Smith
mattrixx.net
SourceConnect - mattrixx
AVID Collab user - mattrixx
MacStudio Ultra / LogicProX / IzotopeRX10+ / SourceConnect / MelodyneStudio5 / WAVES Mercury / NI KompleteUltimate / ProToolsUltimate / RME UFX, UFXII, Babyface / AVID S3 + DOCK / Barefoot MM27 gen2 / Barefoot FP01
Old 06-27-2019, 01:20 PM
Hi, thanks for responding, but I don't think I made myself clear. When I first load up a session in Pro Tools, the OLEDs look like in pic1. As soon as I click on an insert, the bottom windows go full of dots, as in pic2. This started happening after the previous update to EuControl. Before that it was fine.
Old 06-27-2019, 01:30 PM
Yes. That is what mattrixx is referring to. There are settings in EuControl General to change this behaviour to whatever you want.
Old 06-27-2019, 01:46 PM
Ah, I see...
Old 06-27-2019, 02:46 PM
Thanks everyone...
OLED brightness RogerPaolo Avid S1, S3, Dock and Control App 21 01-26-2022 08:26 AM
plugins and oled's ripekeai Avid S1, S3, Dock and Control App 1 05-17-2019 08:47 PM
S3 OLED random issue mattrixx Avid S1, S3, Dock and Control App 7 04-10-2019 09:18 AM
OLED eq graph Macsearcher Avid S1, S3, Dock and Control App 9 10-26-2018 02:02 PM
question about oled parameters robertg Artist Series 0 12-29-2010 02:17 PM
