Old 10-26-2009, 10:49 AM
teleric teleric is offline
Default 003 rack host light blinks
Hello to all of you,
My problem is :
003 rack, was working were i tested it.
On my laptop, installation is ok but
when i launch pro tools LE 7.4cs10 (internet explorer 8 removed, with new ilock driver), the host light doesn't stay on. It switches from on to off to on.
I succeeded to register pro tools, but then when trying to record, it said that i had a problem with the clock.
Now, pro tools doesn't even go to the end of the launching bar because the 1394 host light switches back off before the end.
I use a new fw express card with TI chipset.
What could be the trouble? my macway hardrive (oxford chipset) also doesn't mount correctly (it appears on the desktop but i can't get in - systems gives an error message).
I tried everything digi says to try, without effect.
Is there something here i don't see?
Please help! I'm totally stuck.
Thanks,
My set up is:
003 rack
PT LE 7.4cs10
SiSoftware Sandra
Système
Modèle : Fujitsu Siemens AMILO Pi 1505
Processeur
Modèle : Genuine Intel(R) CPU T2050 @ 1.60GHz
Vitesse : 1.6GHz
Noyaux par Processeur : 2 Unité(s)
Threads par Noyau : 1 Unité(s)
Type : Mobile, Double Coeur
Cache de Données Interne : 2x 32ko, Synchrone, Ecriture Directe, jeu à 8 voies, 64 octets de taille de ligne
Cache sur Carte L2 : 2Mo, ECC, Synchrone, ATC, jeu à 8 voies, 64 octets de taille de ligne, 2 partages de threads
Système
Compatibilité de Plate-forme : Intel Centrino
Carte mère : Fujitsu Siemens AMILO Pi 1505
BIOS Système : Fujitsu Siemens 1.14C 07/30/2007
Bus : ISA PCI PCIe IMB PCMCIA USB FireWire/1394 i2c/SMBus
Support MP : Non
APIC MP : Oui
Mémoire Totale : 1016Mo DDR2 SO-DIMM
Chipset
Modèle : Fujitsu Siemens 955XM/945GM/PM/GMS/940GML Express Processor to DRAM Controller
Vitesse du Bus Principal : 4x 267MHz (1GHz)
Mémoire Totale : 1Go DDR2 SO-DIMM
Mémoire Echangée : 8Mo
Vitesse du Bus Mémoire : 2x 534MHz (1GHz)
Module(s) de Mémoire
Module de Mémoire : Hynix (Hyundai) HYMP564S64BP6-C4 512Mo DDR2 SO-DIMM PC2-4300U DDR2-534 (4-4-4-12 3-16-4-2)
Système Vidéo
Adaptateur Vidéo : Mobile Intel(R) 945GM Express Chipset Family (8 SP 250MHz, 128Mo DDR2, Graphiques Internes)
Dispositifs de Stockage Physiques
ST98823AS (80Go, SATA150, 2.5", NCQ, 8Mo Cache) : 75Go (C:)
_NEC DVD_RW ND-6750A (ATA33, DVD+-RW, CD-RW, 2Mo Cache) : 3Go (D:)
SCSIVAX DVD/CD-ROM (SCSI, SCSI-2, DVD+-R, CD-R, 512ko Cache) : N/A (E:)
Dispositifs de Stockage Logiques
SYSTEME (C:) : 75Go (NTFS) @ ST98823AS (80Go, SATA150, 2.5", NCQ, 8Mo Cache)
AMILO 40 (D:) : 3Go (CDFS) @ _NEC DVD_RW ND-6750A (ATA33, DVD+-RW, CD-RW, 2Mo Cache)
CD-ROM/DVD (E:) : N/A @ SCSIVAX DVD/CD-ROM (SCSI, SCSI-2, DVD+-R, CD-R, 512ko Cache)
Périphériques
Contrôleur Hub LPC 1 : Fujitsu Siemens 82801GBM (ICH7-M) LPC Interface Controller
Périphérique Audio : Fujitsu Siemens 82801G (ICH7) High Definition Audio
Codec Audio : Motorola Motorola SM56 Data Fax Modem
Codec Audio : Realtek Semiconductor 861 High Definition Audio
Port(s) Série(s) : 6
Contrôleur de Disque : Fujitsu Siemens 82801G (ICH7) Ultra ATA Storage Controller
Contrôleur de Disque : Fujitsu Siemens 82801GB Mobile I/O Controller Hub SATA cc=AHCI
Contrôleur USB 1 : Fujitsu Siemens 82801G (ICH7) USB Universal Host Controller
Contrôleur USB 2 : Fujitsu Siemens 82801G (ICH7) USB Universal Host Controller
Contrôleur USB 3 : Fujitsu Siemens 82801G (ICH7) USB Universal Host Controller
Contrôleur USB 4 : Fujitsu Siemens 82801G (ICH7) USB Universal Host Controller
Contrôleur USB 5 : Fujitsu Siemens 82801G (ICH7) USB 2.0 Enhanced Host Controller
Contrôleur FireWire/1394 1 : 22136 XIO2200(A) IEEE-1394a-2000 Controller (PHY/Link)
Contrôleur FireWire/1394 2 : Fujitsu Siemens Integrated OHCI IEEE 1394 Host Controller
Contrôleur SMBus Système 1 : Intel 801xx/63xx SMBus
Imprimantes et Fax
Imprimante : PDFCreator (4000x4000, Rendu des Couleurs)
Imprimante : Microsoft XPS Document Writer (600x600, Rendu des Couleurs)
Services Réseau
Adaptateur(s) Réseau(x) : Intel(R) PRO/Wireless 3945ABG Network Connection - Miniport d'ordonnancement de paquets
Adaptateur(s) Réseau(x) : Realtek RTL8139/810x Family Fast Ethernet NIC - Miniport d'ordonnancement de paquets (Ethernet, 100Mbps)
Gestion de l'Énergie
Etat de la Ligne AC : Connecté
Système(s) d'Exploitation
Système Windows : Microsoft Windows XP Personnel 5.01.2600 (Service Pack 2)
Compatibilité de Plate-forme : x86
Old 10-26-2009, 11:42 AM
Default Re: 003 rack host light blinks
I also have to menion that this laptop working very well with my previous setup : Mbox and PT LE 6.9.
Any help would be much appreciated.
Old 10-26-2009, 11:46 AM
TOM@METRO's Avatar
First, try different firewire cables. Are you using internal clock?
~ tom thomas
Formerly hobotom
HD Omni and 192 I/Os
Windows 10
Intel Hexcore i7
All Samsung Pro SSDs
Ampex MM1200 2" 24 trk tape
www.metrostudios.com
Old 11-10-2009, 05:09 AM
yes i tired different FW cables.
The clock is internal audio clock.
My Mbox is working fine with PTLE 7.4cs10
Apart from the Xpress card that is not digi aproved, is there anything strange in my laptop report that wouldn't let the FW port to perform correctly?
Thanks a lot.
Old 11-10-2009, 01:13 PM
DigiTechSupt's Avatar
It doesn't appear either of these have a TI chipset - did you have your expresscard plugged in while running the Sandra report? Which expresscard are you using, specifically?
Avid Audio Tech Support
Support FAQ
Old 11-12-2009, 06:02 AM
I had the Xpress card running, It is the first on the list. The seller told me it was indeed a Texas Instrument chipset, but i now have a feeling that the card has some problem.
The SIIG card is only sold in the U.S.; didn't find any dealer around here.
For you guys in Europe, What Express card works for you?
Old 11-26-2009, 01:16 PM
Got a new FW Xpress card with TI chipset from Lindy. Same results.
I cannot get my hard drive to word nomally with the firewire ports either. What the hell is going on in this computer.
Reinstalled everything from scratch: nothing worked.
Digi support is really stinking. Anyway...
Old 11-26-2009, 02:20 PM
flautista's Avatar
flautista flautista is offline
support= SOPOR
Jascha Koneffke flutist
www.prodmusica.cl
GA-X58A-UD3R[/
I7 950
RAM 24Gb corsair 1600 (3 sticks)
9-9-9-24
MAC
MacBookPro i7 2,3 15"
RAM 16gb
PT 11.3
003 Rack
MBox 3 Pro
003 rack is not connecting. Blinking green light. no HOST 1394 light. ccgascity1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 01-14-2011 12:41 PM
003 Rack Host light doesn't light...pt crash Kourquie 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 11-03-2010 09:07 AM
003 rack Host light blinking - HELP! rockwell81 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 01-20-2010 07:53 PM
1394 light on my Digi 002 Rack blinks and locks up mseans 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 10-12-2006 03:20 PM
002 Rack Midi light Blinks while idle Ping Pong 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 08-16-2006 08:36 AM
