Re: Help me make sense of these ADC readings ...
Post the session, no audio.
Impossible to tell without seeing whats on the audio tracks.
www.HellfireBeats.com UAD 2 Apollo Quad w/Thunderbolt 3, UAD 2 Satellite Octo TB3, UAD 2 Octo PCIe, Avid S1, Neve R6 500 Chasis, Neve Portico 511, Neve Portico 551, Dangerous DBox+, Focal Trio6 Be, Neumann TLM49, Akai MPC 2000XL, Akai MPC X, Mackie 1202VLZ Pro, Akai Advance 61 Pro Tools 2021.12 Mac Pro 7,1 2019, 8 Core, 48GB RAM - MacOS 11.6.2 16" MacBook Pro 2021, M1 Pro, 16GB RAM - MacOS 12.1 27" iMac, Late-2012, 3.4GHz i7, 24GB RAM - MacOS 10.15 |
He wants to inspect the routing,
Yeah, that's what I'm saying. How the audio tracks are routed, what sends are on them, if they are sending to multiple aux's, etc. Example, if he has an audio track sending to both 9-10 and 11-12, I'm sure that would probably cause some issues being that 11-12 is also sending to 9-10. Just a theory.
PT 2018.10 Windows 10 x64. RME Fireface 802. |
#16
The routing in this session is very simple. And the ADC readings on the audio channels all make sense. Plugin delay plus ADC always adds up to 5874. I have a feeling it's just that the ADC values are not displayed correctly but ADC actually works fine. Otherwise the fx returns would sound totally off.
#17
The lead vocal track is sending to both a reverb (9-10) and a delay (11-12). And that delay is sending to the reverb. I don't see how this could cause any problems. Besides, when I removed the send from the delay (screenshot 2), not much changed.
#18
This is the issue thats been confirmed. Stay away from freezing auxes and leaving the sends or using any kind of bussing with no destination. Like routing multiple aux inputs to a bus and using the bus to record to an audio track...
Mac OS 12.7.2 Monterey (19H15) Mac Pro 2013 (Trashcan) 6 Core 64 gigs Ram, Red Line 16, Native Thunderbolt, ProTools Ultimate 2024.3.1 Macbook Pro, 2019 (15,1) Mac OS 13.6.6 Ventura,32 Gigs Ram,2.3 GHz I9 8 Core ProTools Ultimate 2024.3.1, Apollo 8 Silver,TwinX. |
#19
Ok guys, here are the screenshots of the entire session. Very simple. Only 1 output. No hardware inserts. Who can solve the mystery of the ADC readings?
Maybe I can contribute something myself. Today I set up a test session with 2 audio channels and 2 aux fx channels. I added some plugins and routings and realised how quickly it becomes difficult to keep track of ADC values. Picture 1 is very straightforward: Aux 1 causes the most delay: 2306 samples. Every other channel is therefore delayed by 2306 samples minus its own delay. The sum of all ADC readings is always 2306. On picture 2 it gets more complicated. Now Audio 2 (which has a plugin causing a delay of 62 samples) is routed to the fx channels. The total delay of the session should therefore equal 2368 samples. This is correctly reflected in the ADC reading of Audio 1. BUT: the 2 aux channels don't display the additional delay. Their ADC readings remain at 2306. I'm thinking this is a fault, as the fx channels should also be compensated by the additional 62 samples. On picture 3 it gets interesting. Now Aux 2 is sending to Aux 1. That increases the total session delay to 3540 samples (= 2306 + 1172 + 62). Again, this is correctly reflected in the ADC reading of Audio 1. But again, the 2 aux channels don't show this additional delay! To sum it up, I still believe the readings on the aux channels are wrong but the ADC process works correctly. I set all the fx signals to dry only so I could check if they are phase accurate with the signal coming from the audio channels and the absolutely are.
#20
Could you please make some music while wondering about this?
Does this make any sense????? | hecatomb | MIDI | 7 | 07-09-2007 07:12 AM |
does this make sense?? | richsorr | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 03-21-2007 12:09 PM |
Does this make sense to anybody? | magnolia1 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 08-18-2006 12:48 PM |
Does this make sense to anyone? | landford | Post - Surround - Video | 1 | 09-27-2004 05:36 PM |
Does this make sense??? | VincePro | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 09-17-2002 09:42 AM |
