Old 01-23-2001, 03:29 PM
GS-DK GS-DK is offline
Default Power cycle
Hi
Sorry for a stupid question, but what does it mean to power cycle the computer
thanks in advance
GS
Old 01-24-2001, 11:02 AM
Extreme Mixing Extreme Mixing is offline
Default Re: Power cycle
Shut down, turn everything off. Then turn it back on again.
Steve
Steve Shepherd
Extreme Mixing
Old 01-24-2001, 11:04 AM
philter philter is offline
Is a simple 'restart' not considered a power cycle?
Old 01-24-2001, 02:25 PM
DMR DMR is offline
The term "Power-cycle" is open to (mis?)interpretation. It is probably more accurate to differentiate between a "warm boot" and a "cold boot".
A warm boot (Restart) will reinitialize the computer, which may clear up higher level problems, but it does not fully shut down power to the entire system. This means that some cards (network cards come to mind) may not get fully cleared. Also, a restart won't reset peripherals which are not powered by the computer.By shutting the computer down and powering off any peripherals for a few seconds before restarting (a "cold boot"), you can be pretty sure that everything will be properly reset.
(Actually, even when the computer is "shut down", there is still a standby voltage being supplied to the motherboard. This is what allows the computer to be turned on from the soft switch on the keyboard. To *really* shut down, you have to unplug the beast )
[This message has been edited by DMR (edited January 24, 2001).]
how to power cycle? cjs102460 ProControl, Control|24, Command|8 0 10-17-2010 05:50 PM
must power cycle between big sessions, why? dopplah Pro Tools TDM Systems (Win) 1 04-04-2010 08:52 AM
MBox 2 Pro Power Cycle Issue??? Tulane Sound 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 02-07-2010 02:32 PM
Always have to re power cycle 003R..... Dogcode 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 101 10-15-2009 05:40 AM
G4 Power Cycle zoggied General Discussion 8 10-14-2002 11:26 AM
