Re: U87 with Focusrite Voicemaster Pro? Good combo?
One more question:
If I purchase the Avalon preamp, will I be able to plug it into my computer through my Mbox 2, and can I bypass the Mbox preamp? Matt |
Yes. Use the line ins.
The Avalon 737 is definitely a great piece. around $1700.00 with a pre, an EQ, comp, and de-esser. If you divide that in parts, you could be buying a compressor thats about $400 dollars. Just think in terms of what you really want. As far as I was concern when I got my API A2D, I just wanted the cleanest digital signal going in. That is why I use it spdif. My api compressor is hook to it, and I can tell you...for my uses it doesn't get any better than that. If I were in your position I'll go for a class A stereo preamp, and forget about the channel strip type.
Camilo Toledo |
Where the hell do you get a 737 for $1700?
That's more like it SHOULD cost. $2250 is the cheapest I've seen without hunting too deep. The Buzz Audio ARC is a much much better box, but will also set you back around $2900. The Sebatron Thorax is a good unit if you want valves at just under $2000. Or Seb also has a solid state pre/comp call the Proxima which is just under $1000. And there's plenty more.
http://www.oneearthproductions.net |
www.sca-soundstudios.com |
Man... that really went up. I got mine about a year and 1/2 ago.. I think it was $1750.00
Camilo Toledo |
If you're handy with a soldering iron I'd be going for something like Seventh Circle Audio's N72 or A12 preamps or have alook at JLM Audio kits too. If you're even mor ambitious then have a look at some of the projects at Group DIY.
I have built the 9K (clone) preamps and API312 (clone) preamps and imho the Avalon can't get near these. I have a pair of Neve 1272 clones nearly finished too.... |
Focusrite Voicemaster Pro | Gary H | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 09-03-2004 10:55 AM |
focusrite voicemaster good for just vox? | pedrohead | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 07-12-2002 09:30 AM |
OT: Focusrite voicemaster | Bastiaan | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 05-30-2002 02:30 PM |
Focusrite Voicemaster, should I ?? | BboY | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 03-19-2001 10:56 PM |
Should i get it ? "Focusrite Voicemaster" | BboY | Tips & Tricks | 0 | 03-19-2001 12:11 AM |
