BUG - Incorrect subpaths when using "New Track" in Send or Output menu
Subpaths to surround paths are being incorrectly assigned when using the "New Track" feature from the Send or Track Output dropdown menu. The subpaths get assigned correctly when creating paths and/or auto-creating subpaths in the I/O Setup page, but not when using the "new track" feature. Pic attached.
I'm not sure how far back this goes, but I've tested it on a MacBookPro 10.14.5 with 2019.10 HD|Native TB + Omni, as well as a nMP 10.12.6 with 2019.5 HDX2 + HD I/O.
Scott Gatteño Last edited by originalscottyg; 12-03-2019 at 12:58 PM. |
Re: BUG - Incorrect subpaths when using "New Track" in Send or Output menu
I'm pretty sure this is a bug. So, if anyone else can confirm, I'll start a support case with Avid.
Thanks!!
Scott Gatteño |
Confirmed, PT Ultimate 2019.10 AND 2018.12 Ultimate (both HDX / macos 10.12.6)
Thanks for confirming. I'll start a support case when I get a sec. I don't have 2019.12 in my account yet. Can you tell me if they have dropped Sierra (10.12.6) support? EuControl 19.12 minimum compatibility is is High Sierra, so wondering if they will do the same with Pro Tools 2019.12.
Thanks! EDIT: Just re-read and noticed you said 2018.12, not 2019.12. My apologies.
Scott Gatteño Last edited by originalscottyg; 12-05-2019 at 09:29 AM. |
Hot key for scrolling "ticks/samples" in New Track menu | dbo | macOS | 2 | 05-08-2019 12:48 PM |
"Reset" of a track's inserts and send slots? | Sir Hannes | Pro Tools 12 | 8 | 01-17-2018 09:19 AM |
Keyboard Shortcut for "Track List", "MIDI Editor Pane", and "Clip List" | EdgarRothermich | Pro Tools 12 | 2 | 10-04-2017 02:18 PM |
offline bounce from Send or Track outputs - track "freeze feature" | OliverH | Pro Tools 11 | 20 | 05-25-2014 04:45 PM |
Why send tracks to hardware outputs instead of "Master" track/bus? | gopher | Getting Started | 11 | 01-03-2014 12:12 PM |
