How are native instruments plugins on PT8.
I'm thinking of buying komplete 7 and getting pro tools 8 on september 1 when komplete 7 comes out. My main concern is battery I have to have that.
Re: How are native instruments plugins on PT8.
For a while, there were some problems, but in the last year or so, they've really worked out a lot of the bugs. Many users are using NI stuff just fine now.
The most important thing is when you're installing, to make sure you download the latest updates to the programs. Also, it seems to help, once everything is installed and updated, to open each program in standalone mode first, before trying to open it as a plugin in Protools (or any other DAW). It seems like this helps with the initial setup. Also, try to make sure you have at least 4gb ram in your computer, and even more would be helpful. Finally, it's recommended by most manufacturers of sample-based instruments to use a dedicated hard drive for your samples. Not the system drive and not the drive you record audio onto. |
Thanks alot!
Should I use a usb hard drive or firewire for my samples?
Komplete 6 works here. Not sure about 7 yet since it hasn't been released but I suspect it will be even better.
No USB drives. A better option would be another internal drive for your Sample Libraries. E-Sata is also an option. Firewire is OK, but performance is always better on internal and E-Sata.
Brian Windows 11 Pro | macOS 12 Pro Tools 2022 benonistudio.com Youtube Channel - benonistudio Plugin Deals @benonistudio |
Is there any internal hard drive in particular you think I should get?
Newegg is out of the 640GB SATA III drives right now, all they have is 1TB. http://www.newegg.com/Product/Produc...82E16822136533 http://www.newegg.com/Product/Produc...82E16822136283 http://www.newegg.com/Product/Produc...82E16822136319 http://www.newegg.com/Product/Produc...82E16822136320 I never did ask if you have a PC or Mac, or Desktop or Laptop. If you want to use the drive as an external E-Sata, this case works good, I have 2. It comes with an E-Sata bracket if you dont already have the port. http://www.newegg.com/Product/Produc...82E16817173042 of course the bracket only would work if we are talking about a desktop
Im on a desktop pc. I have a asus m2n-sli deluxe motherboard. I'm extremely ignorant on computers. I know i'm going to need two hard drives. One for my ikmultimedia and native instruments samples and another one for audio since everyone tells me that its better to have an internal for audio rather than external firewire. All those hard drives you listed will work with me motherboard right?
Any of those drives will work.
Thanks alot!
Native Instruments Plugins / PT 10 Issue | everlast88az | Pro Tools 10 | 0 | 11-19-2012 01:52 PM |
PT 7.3 with Native Instruments plugins HELP!!!! | kindsounds | Pro Tools TDM Systems (Mac) | 0 | 07-03-2008 06:23 AM |
Native Instruments PTDM PlugIns trouble at 7.1 | Tonabteilung | Pro Tools TDM Systems (Mac) | 3 | 05-19-2006 02:32 PM |
My native instruments plugins WONT LOAD HELP | The Grand Wizard | Pro Tools M-Powered (Win) | 1 | 07-26-2005 05:59 PM |
native instruments plugins | adam_w1 | Tips & Tricks | 5 | 04-19-2002 05:47 PM |
