Old 06-15-2023, 11:28 PM
basehead617 basehead617 is offline
Default When the MTM doesn't come up
I turn the S6 on the same way every day - haven't had an issue before through a few weeks. Usually a couple seconds after the power is on, both the touchscreen and the display module come up with the Avid logo, etc.
Today turning it on, it seemed to take longer for things to start up - eventually it was just a black screen on the MTM with a mouse pointer and nothing else, and with the purple light on each module (which each came up very slowly). It basically did not fully boot.
I did a whole power down of the UPS and the computer that's on that UPS and started everything up again from scratch and it booted - however it does seem like the MTM and display module don't show anything on the screen as fast as it did before the failure, like it's taking longer to boot.
Is there anything I can check or send regarding logs that would show why the boot failed? I'm worried there's something iffy..
This is a new MTM/new system/etc - latest software..
Old 06-16-2023, 09:02 AM
EddieJones's Avatar
Default Re: When the MTM doesn't come up
There are a few reasons why this may happen. Although its an industrial computer inside...its still a computer with CPU, Memory, SSD etc. It could have been some piece of hardware that didn't come online or a corrupt file that is now repaired. Keep an eye on it and post again here if it happens again. I don't think logs would help as it does appear to have even run the MTMApp.
PT HD 11.3.2 doesn't see my 192 i/o lolo-m Pro Tools HDX & HD Native Systems (Win) 3 04-10-2018 06:47 AM
Shuffle doesn't shift volumes - copy & paste doesn't copy automation marcnyc Pro Tools TDM Systems (Mac) 2 03-12-2010 12:46 AM
It doesn't do something it used to davegibbon 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 09-28-2008 09:17 PM
PT doesn't Doesn't Draw Some Waveforms savage Pro Tools TDM Systems (Mac) 3 01-10-2006 12:21 PM
DMA Box Doesn't Appear JFogarty 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 07-14-2002 03:27 PM
