Old 03-05-2023, 08:32 PM
Default Viewing angle adjust?
Hey - sorry for the silly question, but I'm spending more and more time on an S6 these days. Is there a viewing angle/brightness adjust for the Soft Key display mondules? I mean, if I'm looking at them from directly overhead they're bright enough, but at the typical angle you're at when seated at the console they're almost unreadable. Am I missing something?
thanks!
rich
http://www.richbreen.com
Mac Studio / Ventura, PT 2023.12.HDX, Avid HD I/Os and Metric Halo ULN8, 3xS1/Dock
Also running a Mac Studio Ultra / Ventura / HDX / MTRX / S6
Old 03-05-2023, 09:03 PM
its2loud its2loud is offline
Default Re: Viewing angle adjust?
The brightness settings of the panels are customizable to your liking.
https://avid.secure.force.com/pkb/ar...ness-and-Color
Others might chime in regarding their experience and suggestions.
Old 03-06-2023, 08:07 AM
thanks - Yes, know about that for the knob and control modules, but I don't think it works for the soft key disiplay screens does it? Again, it's a viewing angle problem.
Old 03-06-2023, 10:02 AM
basehead617 basehead617 is offline
Is your S6 in custom furniture? It shouldn’t be lying completely flat..
Old 03-06-2023, 10:34 AM
Nope - it's the standard Avid base.
Old 03-06-2023, 11:47 AM
Maybe Jeff can chime in. I've never had a problem reading the Soft Key Modules. Maybe there's something wrong with the displays?
Old 03-06-2023, 01:47 PM
EddieJones's Avatar
System settings - OLED, TFT and Display Module brightness. Never heard of them not being visible. They are full viewing angle spec displays.
Old 03-11-2023, 01:30 PM
Yup, that's cranked. OK, I guess I'm not missing anything, if I'm right over them they're fine, but if I'm at normal sitting position viewing them at about 30 degrees they're very dim. FWIW, the Display Module Brightness setting seems to have all it's range from 0 to 40% - from 40% to 100% there's essentially no difference on any of the TFTs, OLEDs, Soft Key modules. Some issue or is this just the way it is?
Old 08-31-2023, 08:03 AM
So revisiting my original post many months later: We just had to replace one of the softkey display modules as it was completely dead, and the problem is clear now. Attached is a picture of our display modules; the upper one is still the original and the lower one is new - you can see the upper one is extremely dim. These have always been like this since we got it (very early in the S6 production run.
So was this a problem with early S6s or is this one just broken and has always been so? Thoughts?
File Type: jpg 71512032725__4607543E-5436-4EAF-8D73-7F32D6BD17E3.jpg (29.7 KB, 0 views)
Old 08-31-2023, 08:38 AM
EddieJones's Avatar
I didn't realize you had one of the first S6's. Yes (like mine) these are not as bright. They are however a lot higher resolution. We had to change as they weren't made anymore. The screen we use today is brighter yes.
Right-angle Lightning cable Righty27 Avid S1, S3, Dock and Control App 45 06-10-2016 05:39 AM
Pro Control Mounted at an Angle Barry Johns ProControl, Control|24, Command|8 3 02-01-2015 12:04 PM
S3 optimum angle? RyanC Avid S1, S3, Dock and Control App 3 01-04-2015 04:52 PM
Avid/MC Control v1 viewing angle smfelton Artist Series 1 04-30-2012 11:56 AM
Fine adjust fader in edit window caput! command+adjust crizdee Pro Tools TDM Systems (Mac) 2 12-09-2008 03:55 PM
