Old 04-29-2015, 01:28 PM
NYCBex NYCBex is offline
Default Unable to record to External Hard drive
Hello -
I recently purchased the Pro Tools Express 10.3.4 for audio book recording. I can record to my computer (which I know is not ideal), but am unable to record directly to my external hard drive - Passport Ultra 1 TB -
When I try to connect them, I get an error message -5000 that reads I am not authorized to connect Pro Tools to the hard drive.
My computer is a MacBook Pro - with the Yosemite update.
Can someone help?
Many thanks
Old 04-29-2015, 02:02 PM
Default Re: Unable to record to External Hard drive
Originally Posted by NYCBex View Post
Hello -
Can someone help?
Many thanks
First off PT10 any version is not supported on Yosemite any version. To even get it to be loaded one has to hack the installer and that's not for the faint of heart. See if you can back date to an earlier version of OSX like OSX 10.8.5 (Mountain Lion) which was the last supported OSX for PT10.
Jack
QAPLA!
Old 04-29-2015, 04:23 PM
Let me be a little more clear - I can record PT 10.3.4 on my computer (Yosemite - no hacking needed) - but I cannot record directly to my external hard drive -
Thanks
Old 04-29-2015, 04:45 PM
Thanks
But you had to have hacked the installer (or used Migration Assassin) to get PT10.3.4 on a Yosemite computer. And like I said you'll get no help from anyone here or Avid because as I wrote PT10 any version isn't supported on OSX above OSX 10.8.5. No doubt you've run into the issue of not seeing the plugin lists on inserts until you mouse over them (and that's just one issue with trying to run PT10 on Yosemite). And it's this incompatibility that's probably causing your issue.
Jack
QAPLA!
Old 04-30-2015, 03:04 AM
I didn't hack into anything (I wouldn't know how to) - the program loaded up without any sort of problem. First, what I'd like to know is what error message -5000 means. If someone can help me with that I'd be grateful.
Old 04-30-2015, 03:49 AM
I give up. I keep telling you there's no way without messing with the installer of even loading PT10 on Yosemite unless you did an in situ upgrade of OSX from whatever version was on your machine before. Even though Apple says that's their recommended way to do things it's not a good idea, especially with something as complicated as PT. I also keep telling you PT10 any version is not supported on Yosemite and that that may well be the root of your issues.
The reason you can't install PT10 on Yosemite is the installer sees OSX10.10.1 as OSX 10.1 which would be a very early version of OSX (much earlier than the last supported OSX of 10.8.5 for PT10). That is of course if you're running a legitimate copy of PT and not crackware.
Jack
QAPLA!
Old 04-30-2015, 03:55 AM
Phil Ogden Phil Ogden is offline
It sounds like a permissions error. Go into PT 'Workspace' and check that the HD is set to Record (R).
You might also want to check at OS level that that you have both read and write permissions for the HD ("Cmd I").
Finally, make sure that the HD is formatted in line with Avids recommendations.
Though as Musicman691 says, the problem might be related to the unsupported configuartion you have.
Old 04-30-2015, 06:32 AM
Craig F Craig F is offline
-5000 is OSX's "YOU DO NOT HAVE PERMISSION TO THIS" error
also 99% of all off the self preforrmatted drives come formatted FAT32 so if you haven't reformatted HFS+ Journaled you have not done what you need to use the drive with your MAC
Thank you,
Craig
Old 04-30-2015, 09:01 AM
wmcintyre wmcintyre is offline
PT 10.2.10 is supported on Yosemite...
scroll down for the Mac OS compatibility grid
http://avid.force.com/pkb/articles/c...m-Requirements
Old 04-30-2015, 10:01 AM
ArKay99 ArKay99 is offline
Do what Craig and Phil say and you'll most likely be GTG.
Mac Pro 6.1, E5-2690 V2 10 core 3.0G, 32gig 1866 memory, 512G PCIe system drive, 4 480G OWC 3G SSD data drives in Thunderbolt 2 enclosure, macOS 10.15.7, Pro Tools Ultimate 2020.9.1, Twin Raven MTi's, Apollo 8 TB, 2 UAD2 Satellite Octo Thunderbolt, RME ADI-4 DD, Neve 5012, 5043, Bricasti M7, 2 PCM 92's, M350, DynAudio BM6 MK 3, BM14S, a bunch of cool mics...1 damned iLok2.
external ssd drive: unable to create record files for one or more tracks hotel17 Getting Started 5 06-09-2020 07:25 AM
Unable to Save to External Hard Drive Mistermac macOS 11 07-28-2014 07:49 PM
Do I REALLY NEED An External Hard Drive To Record? MetalDrummer13 General Discussion 13 03-20-2011 04:24 AM
Workspace unable to find external hard drive Darryn Farrugia Storage Subsystems 0 12-06-2010 10:49 PM
To to be able to record to External Hard Drive!!! stringplayer 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 11-28-2010 12:44 PM
