playlists
Hi!
On an audio track, you can switch to "playlists" to view multiple takes simultaneously. Is this possible with a midi track? Thank you! |
Re: playlists
I dont believe so.... There was a request in ideascale I believe.
-Systems Engineer, Systems and Sound Designer, Recording and Mixing Engineer |
Re: playlists
No. MIDI tracks do not have playlists sadly.
My Gear Mac Pro (mid 2011) - 2x 2.8GHz Quad-Core Xeon, 16GB RAM, ProTools HD Native, UAD Quad. HD IO 16x16 + Lynx Aurora 16 Solid State Logic Matrix B&W 800 series + Yamaha HSM80s Mojave Audio, Royer, Neumann, Audix, Yamaha, AKG and Shure mics. Focusrite ISA828, SSL Alpha VHD, UA LA610-mkii, M-Audio OctoPre, Avid Eleven Rack Canare and Mogami cabling. http://www.boomsounddesign.com |
Re: playlists
Sadly is right! I've been asking for this for a while. My "solution" is to add a couple of midi tracks below(EDIT window) my instrument track, so if I get a take that's worth saving, I copy it to one of the midi tracks. Not elegant at all, but better than nothing
Re: playlists
Well... that's too bad... I guess midi performers don't get as much credence as live ones, though that's really not fair. Midi is sometimes harder than a live performance.
If I may extend this post... with another question... Rather than playing overly complex lines into pro tools, I've found if I just notate them in Sibelius, then export them as midi into Pro Tools, I get a much more accurate take. After the midi is in pro tools, I assign it to whichever instrument, usually from Vienna Symphonic Library. Problem is, the patch changes don't work. Is there any way to make pro tools trigger a patch change at a certain time? Say for instance, first three notes staccato, second one legato. Thank you!! |
PT 8 playlists | DonaldM | Tips & Tricks | 6 | 07-06-2009 10:26 AM |
anybody use playlists? | mwingerski | Pro Tools TDM Systems (Mac) | 15 | 05-02-2007 09:55 AM |
Playlists | FullFreq | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 09-29-2004 02:14 PM |
playlists | Rail Jon Rogut | Pro Tools TDM Systems (Mac) | 2 | 01-08-2003 12:44 AM |
Help With Playlists | Greg M | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 04-08-2002 07:54 PM |
